about interrupt
I don't know how to use interrupt correctlly.Can anybody help me?
Hello yoland,
Please give some more details about what you want to do and which system are using? It is necessary to know if you are using Nios, Nios II, RTOS, Linux, …
Bye,
niosIIuser
I use nios2 .And I build a system with a on-chip ram and a key . I want to servise an interrupt from the key.
the following is my code:# include "system.h"# include "altera_avalon_pio_regs.h"# include "alt_types.h"# include "altera_avalon_uart_regs.h"# include "sys/alt_irq.h"
volatile int edge_capture;
static void handle_key_interrupt(void* context,alt_u32 id)
// int* edge_capture_ptr=(int*)context;
// IOWR_ALTERA_AVALON_PIO_EDGE_CAP(KEY_PIO_BASE);
IOWR_ALTERA_AVALON_PIO_IRQ_MASK(KEY_PIO_BASE, 0xf);
IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0x55);
static void init_key_pio()
/* Recast the edge_capture pointer to match the alt_irq_register() function
* prototype. */
void* edge_capture_ptr = (void*) &edge_capture;
/* Enable all 4 button interrupts. */
IOWR_ALTERA_AVALON_PIO_IRQ_MASK(KEY_PIO_BASE, 0x1);
/* Reset the edge capture register. */
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(KEY_PIO_BASE, 0x0);
/* Register the interrupt handler. */
alt_irq_register( KEY_PIO_IRQ, edge_capture_ptr, handle_key_interrupt );
int main (void) __attribute__ ((weak, alias ("alt_main")));
int alt_main (void)
volatile int i;
i=0;
// alt_u8 led=0x01;
// alt_u8 key;
# ifdef KEY_PIO_BASE
init_key_pio();# endif
i=alt_irq_enabled();
IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0xf0);
while (1)
return 0;
Hello yoland,
Ok, now tell us your problem please. Does the code not work or not work correctly? Which behaviour is incorrect?
Bye,
niosIIuser
Hello niosIIuser
I set the interrupt,but it can't response,that is when i press the key,it couldn't generate an irq.
1. i=alt_irq_enabled(); why the value 'i' is always zero.
2.static void handle_key_interrupt(void* context,alt_u32 id); can't access to this ISR function
THANKS
Hello yoland,
Try the following code if you would like that your LED register is changing from 0xf0 to 0x55 after pressing the button. Please tell me the state of your LED register after executing the code.
* prototype. */
alt_irq_register( KEY_PIO_IRQ, NULL, handle_key_interrupt );
int alt_main (void)
volatile int i;
i=0;
// alt_u8 led=0x01;
// alt_u8 key;
init_key_pio();
//i=alt_irq_enabled();
while (1)
return 0;
thanks.
I will see the handbook and hope find the way to solve it.
