12690 Discussions
accesing a custom component
Hello every body;
I have created my custom component, it have an avalon slave interface, it have 2 slave registers, how can i access these registers if i have the base address, i mean that what is the order of these internal registers,
another question is if this component takes 20 clk cycle to finish, how can i take its output when it just finish.
--- Quote Start ---
--- Quote End ---
Every register you implement in the custom component is supposed to have an address (or offset) inside the MM slave address range. This depends only on your hw design.
--- Quote Start ---
--- Quote End ---
Three options:
- wait at least 20 clk with a sw cycle
- implement a status register with a completion flag bit: then poll the bit until the it signals your data is ready; this is especially useful when the process duration is not constant
- route the completion signal to an irq
