access compactflash?
I'm using the Nios II development kit.
does any body know how to access the compactflash ?
I have managed to read write data to the flash.(u5)
but I don't know how to refer to the compactflash at con3
I suggest that you check out the Microtronix Compact Flash SOPC Builder component & example designs available for download in the "Tested IP" section. In the future Compact Flash will be integrated into the Nios II development kit.
