bin2flash problems
I'm trying to upload a linux kernel image to the Microtronix Stratix development board. The "Nios II Linux Quickstart Guide" says to right click on the build/vmlinux.bin file and select 'upload'. When I do this, I get the following error:
Microtronix Linux Extensions
Version 1.1, Built Wed Jul 7 12:46pm EST 2004
Expected integer value for option 'location'
Value was: 'null'
Using default value: -1
The bin2flash utility converts any binary data file to a FLASH file that
can be used by the flash programmer.
usage: bin2flash [--help] [--debug] [--silent] [--flash=designator]
[--input=file] [--quiet] [--epcs] [--base=addr] [--log=file]
[--location=addr] [--output=file] [--verbose]
Options may be specified in any order.
--base=<addr> flash base address
--debug debug mode
--epcs epcs flash mode
--flash=<designator> flash device reference designator
--help print this message
--input=<file> input Binary file to process
--location=<addr> design location within the flash
--log=<file> file for logging progress
--output=<file> output flash file
--quiet only print errors
--silent silent mode - same as quiet
--verbose lots of interesting information
I&#39;ve been able to sucessfully run bin2flash from the Nios II SDK shell command line where I can specify a value for the --location parameter.
Does anybody know how to specify the location parameter through the Nios II IDE?
Terry
Hi, there is a bug that leaves out an attribute in one of the tags in the <project>.stf file when you apply changes in the project property page.
To remedy this, you can open up the <project>.stf file in an editor and add
offset=&#39;0x0&#39;
to the location_on_target tag.
So your tag should look like this:
<location_on_target offset=&#39;0x0&#39;>
Save these changes and you should be able to upload the kernel image without a problem.
(note: the same problem will occur when applying changes in a filesystem project&#39;s property page; for a filesystem project, the offset should be 0x200000)
This bug will be corrected in the next release of the Nios II Linux Distribution.
Randy,
Thanks for the reply. I tried your suggestion but when I try to do the upload now I get a pop-up window that says:
"Could not read project STF file."
The stf file now contains:
<?xml version=&#39;1.0&#39; encoding=&#39;UTF-8&#39;?>
<stf>
<project name=&#39;kernel_project&#39; ptf=&#39;D:\work\NiosII_Mtx_Stratix\LDK2.ptf&#39; cpu=&#39;cpu&#39;>
</project>
flash_kernel
</location_on_target>
<execution_location>
sdram
</execution_location>
</stf>
Does this look correct?
I was able to work around this problem by using the bin2flash and nios2-flash-programmer command line utilities; so really this is more of a bug report than an urgent problem.
Maybe there should be a bug-report forum or something like that added to this site.
Thanks for the help.
Terry
