12748 Discussions
boot uClinux kernel problem
Hi~
Could you help me, thanks.
The kernel image and .sof is OK.
Then, when I try to download them to DE0 board
I key in command
"$nios2-configure-sof DE0_TOP.sof" and "$nios2-download -g zImage"
They are OK.
But when I key in command
"$nios2-terminal"
It stuck at "PID hash table entries: 32 (order: 5, 128 bytes)"
It can not continue to execute
[NiosII EDS]$ nios2-terminal
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
Uncompressing Linux... Ok, booting the kernel.
Linux version 2.6.19-uc1 (root@ubuntu) (gcc version 3.4.6)# 27 PREEMPT Mon Jul 2
5 20:07:51 PDT 2011
uClinux/Nios II
Altera Nios II support (C) 2004 Microtronix Datacom Ltd.
Built 1 zonelists. Total pages: 2032
Kernel command line:
PID hash table entries: 32 (order: 5, 128 bytes) <--------------stop here
Could you tell me how to solve it
Thank you very much
--- Quote Start ---
5 20:07:51 PDT 2011
--- Quote End ---
This looks like a very old kernel version. Where did you get/build that from? Please follow the instructions from the Altera Wiki (http://www.alterawiki.com/wiki/linux) to get a more recent version of the Kernel and uClinux-dist
Thank you very much.
It work.
Sir,
i want to work with DE0 board under uclinux, myself using ubuntu 10.04, i came to know i cant get images to load under ubuntu ,is it true?, I am very knew to this ,kindly hlep me.
Thanks ,
Alex.
