Hi ...I am working on a custom Cyclone II board. I would like to boot with console on JTAG UART suppport enabled , without using nios2-terminal ... how to go about it ?
From the forum i learned that to boot without nios2-terminal, JTAG UART support is to be removed. Is there any other way ? Where is the code that waits for nios2-terminal ??? Thanks and Regards, VishalLink Copied
Altera didn't release the code or details of jtag uart of nios2-terminal.
You can not use jtag uart without nios2-terminal. You'd better use serial uart (RS232) .- Mark as New
--- Quote Start --- originally posted by hippo@Jul 13 2006, 09:37 AM you'd better use serial uart (rs232) .
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16868)
--- quote end ---
--- Quote End --- Thanks Hippo ! Serial UARTS are bein used for sme other prpose thus i cant use it . Has anyone tried netconsole on nios2 ? Regards, Vishal
