1.
A component is somewhat HDL coded logic or just a line(also coded by HDL). 2. Components were created for Nios II (master) to interface to user logic or external device(Slave).- Mark as New
thank you .my english is not good.
is your means that you can only get slave from interface to user logic? creat new component just gets a master . the avalon timing was writed for what? peripheral or the interface you get from interface ro user logic?- Mark as New
and where do you get the timing standar for the interface to user logic?
A new component resides inside the chip.
User logic is off-chip. So it is addressed via an external bus bridge.- Mark as New
The Component Editor is the method for creating components going forward. "Interface to User Logic" is deprecated. It's as simple as that.
- slacker
