12727 Discussions
eclipse dont show nios perspective
Hello people,
Im having problems to start eclipse-nios2 on Opensuse 13.2, using quartus 13.1. Always i try call eclipse-nios2 from my laptop it only load INDIGO eclipse and dont show any perspective NIOS II.
Here a log contain a debug from NIOS:
# ./eclipse-nios2 -Debug
Start VM: /home/REDBEAR/altera/13.1/quartus//linux/jre/bin/java
-Dosgi.requiredJavaVersion=1.5
-XX:MaxPermSize=256m
-Xms40m
-Xmx384m
-Dosgi.user.area=@user.home/.altera.sbt4e/13.1.0.162
-Dosgi.configuration.area=@user.home/.altera.sbt4e/13.1.0.162/configuration
-Dosgi.configuration.cascaded=true
-Dosgi.instance.area.default=@user.home/sbt4e-13.1-workspace
-jar /home/REDBEAR/altera/13.1/nios2eds/bin/eclipse_nios2//plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
-os linux
-ws gtk
-arch x86
-showsplash
-launcher /home/REDBEAR/altera/13.1/nios2eds/bin/eclipse_nios2/eclipse
-name Eclipse
--launcher.library /home/REDBEAR/altera/13.1/nios2eds/bin/eclipse_nios2//plugins/org.eclipse.equinox.launcher.gtk.linux.x86_1.1.100.v20110505/eclipse_1407.so
-startup /home/REDBEAR/altera/13.1/nios2eds/bin/eclipse_nios2//plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
--launcher.overrideVmargs
-exitdata 1c98004
-product org.eclipse.epp.package.cpp.product
-Debug
-perspective com.altera.sbtgui.ui.cPerspective
-vm /home/REDBEAR/altera/13.1/quartus//linux/jre/bin/java
-vmargs
-Xms40m
-Xmx384m
Configuration location:
file:/home/REDBEAR/.altera.sbt4e/13.1.0.162/configuration/
Configuration file:
file:/home/REDBEAR/.altera.sbt4e/13.1.0.162/configuration/config.ini loaded
Install location:
file:/home/REDBEAR/altera/13.1/nios2eds/bin/eclipse_nios2/
Configuration file:
file:/home/REDBEAR/altera/13.1/nios2eds/bin/eclipse_nios2/configuration/config.ini loaded
Shared configuration location:
Framework located:
file:/home/REDBEAR/altera/13.1/nios2eds/bin/eclipse_nios2/plugins/org.eclipse.osgi_3.7.2.v20120110-1415.jar
Framework classpath:
Splash location:
/home/REDBEAR/altera/13.1/nios2eds/bin/eclipse_nios2/plugins/org.eclipse.platform_3.7.2.v201202080800/splash.bmp
Debug options:
file:/home/REDBEAR/altera/13.1/nios2eds/bin/.options not found
Time to load bundles: 11
Starting application: 3103
Application Started: 12503#
Any help could be very good.
