ethernet support
Hi http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
i use the Nios2 dev Board (2c35). and try uclinux . I followed the instructions from this site
http://nioswiki.jot.com/wikihome/operating...ems/uclinuxdist (http://nioswiki.jot.com/wikihome/operatingsystems/uclinuxdist
and everything worked fine. Now i try to enable ethernet, following the instructions from this site
http://nioswiki.jot.com/wikihome/operatingsystems/ethernet (http://nioswiki.jot.com/wikihome/operatingsystems/ethernet
but i can&#39;t find the menu "Networking" ??? where is it and what do i need to do to get to it
thanks for your help http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
It is in kernel config,
cd ~/uClinux-dist
make menuconfig
Kernel/Library/Defaults Selection --->
(linux-2.6.x) Kernel Version
(None) Libc Version
[ ] Default all settings (lose changes)
[*] Customize Kernel Settings
[ ] Customize Vendor/User Settings
[ ] Update Default Vendor Settings
Then <exit> <exit> <yes> .
It will enter kernel config,
Then in the kernel config menu, you can find the "Networking" in the top level.
