Dear ALLL
I have a DE2 board. Now I want to use the DM9000. I want to know how to connect it to NIOSII . Beacuse I find the uClinux have a drive form DM9000. How to do it when I use the drive in hardware.pls help me !Link Copied
- « Previous
- 1
- 2
- Next »
--- Quote Start --- originally posted by hippo@Nov 7 2006, 02:50 PM did you check the design guide or layout guide of dm9000a?
the layout of tx rx pairs are critical.
did you use the same phy transformer?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19240)
--- quote end ---
--- Quote End --- I'm having a very similar problem with my DE2 board.. it sends ARP packets, and my host pc responds to them, but I don't think the board understands the response because it sends another broadcast right away. This happens three times after every ping command given to the DE2 board. It has a static IP and is connected by crossover cable to the host pc and uses the DE2_NET example. How else can I test it? Thanks in advance http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
- « Previous
- 1
- 2
- Next »
