12699 Discussions
how to debug the plugs ethernet in stratix1s10?
1.With the calling of nr_plugs_initialize(...), why after nios-run the SOPC builder turn to GERMS monitor?
2.how to debug plugs ethernet lib(such as nr_plugs_initialize, or nr_plugs_connect)?
through the SDK shell,
go to the project/*sdk/src/??plugs
nb hello_plugs.c
then while attached to your board,
nr hello_plugs.srec
this will let you do a bunch of things.
Does that help?
