how to recongfig system ?
hi all:
I want to change some configure parameter in inittab file after boot nios2 linux.
Can I config the system again use the updated ininttab file?
If can what command support ?
Thanks a lot!
the init (uClinux-dist-test/user/init/simpleinit.c ) will do rc then inittab.
so you can add your setup to rc, which may update the inittab then.
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
The simplified "init" program will run etc/rc and etc/inittab during startup.
If you want to customize startup, you should update the files vendors/Altera/nios2nommu/ rc and inittab.[/b]
--- Quote End ---
