12551 Discussions
include directory not showing up in compiler command line in make output
I'm a nios ii newbie. I am trying to create a bsp project that uses the Micrium rtos. I got this make error."warning: lib_def.h: No such file or directory". I added the Micrium lib sources to the project. In 'Project > Properties > C/C++ General > Paths and Symbols > Includes > GNU C' I added the directory to include. When I run make, I see in the Console that there is no -I option for the directory I added. I still get the error. How can I get the correct -I option added to the compiler command line? Bill
