Working with the full featured design for 2c35 I bump into the loss of the pin properties in the bank from >clk_to_sdram[0]......ddr_we_n[]<. Suddenly the pins are no longer connected to the location assigned before. An reimport of the pin assignment fails. Even if I save the design this happens.
Does anyone know the reason for this behaviour of quartus 5.0? Thanks in advance. andyLink Copied
Hi Andy,
if you are doing what I am thinking... when you (re)assign pins, you should first close the project and quartus and restart it before you can use it. First save of course before closing it http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif . but it's a bug in Quartus II. good luck, Danny
