make -s
hi all,
im wondering if i could change the build process (not yet found any script or something) in that way, that the suppressed messages will appear! normally when i click "build" it does: "make -s" so, how to remove -s???
thanks!
Choose Preferences on the Window menu, then under Nios II select Show command lines when running 'make'.
HEY! THANKS! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
...i went these options thru but seems didnt read rarefully enough http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif
