nano-X problem
Hello everyone,
I wanted to ask a little question on the forum about nano-X. I followed the complete tutorial on the nios wiki for the Framebuffer, but everytime I try to start "nano-X &" I get the following syntax error:
$ nios2-terminal nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster ", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) Linux version 2.6.34-00701-gc130879-dirty (hacor@localhost.localdomain) (gcc version 4.1.2)# 150 Fri Sep 10 10:25:37 CEST 2010 bootconsole enabled early_console initialized at 0xe8002000 Linux/Nios II-MMU init_bootmem_node(?,0x5d2, 0x0, 0x2000) free_bootmem(0x5d2000, 0x1a2e000) reserve_bootmem(0x5d2000, 0x400) Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128 Kernel command line: PID hash table entries: 128 (order: -3, 512 bytes) Dentry cache hash table entries: 4096 (order: 2, 16384 bytes) Inode-cache hash table entries: 2048 (order: 1, 8192 bytes) We have 8192 pages of RAM Memory available: 26516k/5959k RAM, 0k/0k ROM (1360k kernel code, 4598k data) Hierarchical RCU implementation. NR_IRQS:32 Console: colour dummy device 80x25 Calibrating delay loop... 48.94 BogoMIPS (lpj=244736) Mount-cache hash table entries: 512 init_BSP(): registering device resources bio: create slab <bio-0> at 0 Switching to clocksource timer JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc. msgmni has been set to 51 Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254) io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) fb0: Altera FB frame buffer device ttyJ0 at MMIO 0x8002000 (irq = 10) is a Altera JTAG UART console enabled, bootconsole disabled console enabled, bootconsole disabled physmap platform flash device: 01000000 at 04000000 physmap-flash.0: Found 1 x16 devices at 0x0 in 16-bit bank Intel/Sharp Extended Query Table at 0x010A Intel/Sharp Extended Query Table at 0x010A Intel/Sharp Extended Query Table at 0x010A Intel/Sharp Extended Query Table at 0x010A Intel/Sharp Extended Query Table at 0x010A Using buffer write method Using auto-unlock on power-up/resume cfi_cmdset_0001: Erase suspend on write enabled RedBoot partition parsing not available Using physmap partition information Creating 4 MTD partitions on "physmap-flash.0": 0x000000d00000-0x000001000000 : "romfs/jffs2" 0x000000000000-0x000000020000 : "catalog" 0x000000180000-0x000000d00000 : "application" 0x000000020000-0x000000180000 : "selector" Freeing unused kernel memory: 4200k freed (0xc0155000 - 0xc056e000) ifconfig: socket: Function not implemented Welcome to ____ _ _ / __| ||_| _ _| | | | _ ____ _ _ _ _ | | | | | | || | _ \| | | |\ \/ / | |_| | |__| || | | | | |_| |/ | ___\____|_||_|_| |_|\____|\_/\_/ | | |_| For further information check: http://www.uclinux.org/ BusyBox v1.16.2 (2010-09-07 22:27:30 CEST) hush - the humble shell Enter 'help' for a list of built-in commands. root:/> nano-X & 690 nano-X root:/> sh: syntax error at '&#65533; nios2-terminal: exiting due to ^D on remote ~ $ nios2-terminal nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster ", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) Done nano-X root:/> nanowm & 695 nanowm root:/> sh: syntax error: unexpected ) I tried the tutorial with the neek_Web_server example design and with my custom design, both gave the same results. nios2-terminal automatically exits after giving the syntax error... I'm sure the hardware designs are ok, because when I follow the tutorial to show the console on the neek LCD, it works perfectly.
I did the following steps:
-in the uClinux-dist/user/microwin/src/ I did "make clean" and make, which worked perfectly.
- in the uClinux-dist/ I did "make"
I'm working on this problem for 4 days now, and it's really bothering me. Any help would really be appreciated.
Thanks!
Best,
Hans
Hi!
I don't know if you're still after this issue, but try to check the file type with 'file'. It seems your nano-X binary is not an ELF binary.
steron.
