i am now using cyclone developing board,everytime build the project"hello world",i met the error:
make -s all Syntax error: "(" unexpected make: *** [D:/nios/after/examples/vhdl/niosII_cyclone_1c20/standard/std_1c20_sim/dummy_file] Error 2 Build completed my nios is full futhured,is there somebody know why about this?Link Copied
maybe some key files were deleted by mistakes, you'd better delete Nios II , reinstall it .
A lot of people seem to have either this problem, or some other problems with the dummy_file...
We had the same thing you had, so in the Makefile we simply disabled the part that is looking for a dummy_file When it is otherwise complaining about a dummy_file, we open that dummy file with notepad and save it. Yes it is empty, it is just to change the "Modified Time" This bug is really annoying, Altera should fix it asap...- Mark as New
Very simple:
quartus II 4.1 + Nios II 1.0=OK quartus II 4.2 + Nios II 1.1=OK upgrade or degrade your software to match them. The most possible situation to such a problem is quartus II 4.2+Nios II 1.0
