performance issue
wish to run a program as fast as i can.
does making it run from the on_chip_memory will speed thing up?
i have tried this thing:
int testTimes(void) __attribute__ ((section(".on_chip_memory")));
int testTimes()
but i get the next build error:
39 AM - (SEVERE) elf2flash: Boot copier overlaps data in flash[Jul 12, 2005 10]
does anybody knows way?
surely on_chip_memory will be faster tha an external memory, but to have the best performance u should use tightly coupled memory (nios II 5.0).
What reset and exception address have u set?where is your program,data memory linked?
See the full featured hardware design and the tightly coupled memories example software for more details.
