I have a probelm in building a new SOPC component. I have this new component, the PWM example, and a NIOSII cpu in the project. The PWM works fine (using signalTap, I can see all the read/write control signal changes). However, my new components does not work (with signalTap, read/write control signal does not change. only address change, but not the way I need). Any idea what's going on will be appreciated? Whether I need start a new slave_avalon bus? I think I using the right address for my new module. Thanks a lot,Link Copied
