problem of "if" condition
I wrote a program to process data from PC through uart, but there is something wrong.
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
main()
    init_uart0();
    while(1)
          if(uart0_rbuf_out_cnt != uart0_rbuf_in_cnt )
}[/b]
--- Quote End ---
I receive data in uart0_ISR(), if there is one new byte, at first put it into the uart0_rbuf, and then the uart0_rbuf_in_cnt add 1.
The problem is when (uart0_rbuf_out_cnt != uart0_rbuf_in_cnt ) is true, it can not go into the program to process the data.
What&#39;s the matter?Thanks.
define uart0_rbuf_out_cnt and uart0_rbuf_in_cnt variable as volatile, for example:
volatile int uart0_rbuf_out_cnt
if not, the compiler optimize these variables because they aren&#39;t managed in the main program...
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif Thanks,Soin,I&#39;ll try.
