problem with usb driver
hi,
I have boot uclinux kernel successful,then i plug a usb disk on my board,that's ok.But it show errors when i run the follow code:
[/CODE]fdisk -l /dev/sda
fdisk:Bad command or file name
[CODE]mount -t vfat /dev/sda1 /mnt
FAT:Code page cp437 not found
mount failed:Invalid argument[/B]
please help me,thank you!
TO_BE_DONE
TO_BE_DONE
Hi,hippo.
I have solved the usb problem by enable fdisk in busybox.
Now,I want to programme my apps by using the device driver,how can i do?
Which files should i include?
Thahk you! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
--- Quote Start ---
originally posted by zhengkaike@Jun 4 2006, 10:02 PM
hi,hippo.
i have solved the usb problem by enable fdisk in busybox.
now,i want to programme my apps by using the device driver,how can i do?
which files should i include?
thahk you!  http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/smile.gif
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15884)
--- quote end ---
--- Quote End ---
You can access the mounted usb disk as normal file.
So just include stdio.h and stdlib.h should work.
Hi,hippo.
Could you tell me how to hang a usb disk on my board automatic not by execute
the "mount" command in nios2-termimal?
Thank you!
--- Quote Start ---
originally posted by zhengkaike@Jun 5 2006, 03:12 PM
hi,hippo.
  could you tell me how to hang a usb disk on my board automatic not by execute
  thank you!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15901)
--- quote end ---
--- Quote End ---
You can add the mount command or other initialization into vendors/Altera/nios2nommu/rc .
it will be installed to romfs/etc/rc .
--- Quote Start ---
originally posted by hippo+jun 5 2006, 02:28 am--><div class='quotetop'>quote (hippo @ jun 5 2006, 02:28 am)</div>
--- quote start ---
<!--quotebegin-zhengkaike@Jun 5 2006, 03:12 PM
hi,hippo.
  thank you!
--- quote end ---
--- Quote End ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15902)</div>
[/b]
--- Quote End ---
Hi,hippo.
I have added the mount command(#mount -t vfat /dev/sda1 /mnt)into vendors/Altera/nios2nommu/rc ,but it need to execute mount manual all the same,and there is nothing under the path of /mnt .
please help me!
thak you!
did you rebuild the kernel with,
make
make romfs
make linux image ?
What is your boot message now?
May be you have to add busybox sleep, and wait several seconds for usb disk to be detected before mount usb.
sleep 15
--- Quote Start ---
make
make romfs
make linux image ?
what is your boot message now?
may be you have to add busybox sleep, and wait several seconds for usb disk to be detected before mount usb.
sleep 15
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15911)
--- quote end ---
--- Quote End ---
Sorry,hippo.
I can&#39;t solve the problem.
The mount command always be executed before the usb disk be detected.
my step:
1. add the mount command into vendors/Altera/nios2nommu/rc .
2. make menuconfig
busybox-->[*]sleep
3. make
4. make romfs
5. make linux image
Is there any problem?
Thank you.
add "make -C user/busybox clean" after step2.
boot uClinux,
run "busybox", to see what you have built in busybox.
What is your rc now?
--- Quote Start ---
originally posted by hippo@Jun 5 2006, 08:41 PM
add "make -c user/busybox clean" after step2.
boot uclinux,
what is your rc now?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15934)
--- quote end ---
--- Quote End ---
Hi,hippo.
It can mount usb disk automatic,but show another erro:
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
Command: mount -t vfat /dev/sda1 /mnt
Kernel panic - not syncing: Attempted to kill init!
Execution Finished,Exiting[/b]
--- Quote End ---
My rc:
--- Quote Start ---
hostname uClinux
mount -t proc proc /proc
mount -t sysfs sysfs /sys
mount -t usbfs none /proc/bus/usb
mkdir /var/tmp
mkdir /var/log
mkdir /var/run
mkdir /var/lock
mkdir /var/empty
ifconfig lo 127.0.0.1
route add -net 127.0.0.0 netmask 255.0.0.0 lo# dhcpcd -p -a eth0 &
cat /etc/motd
sleep 15
mount -t vfat /dev/sda1 /mnt[/b]
--- Quote End ---
Now,i hope that it mount usb automatic when usb disk be detected,how can i do?
I wrote a little shell script to mount the USB stick, but I dont know if this is the best solution. I wanted to port autofs first but it was to heavyweight.
For the shell script I use /proc/partitions and /proc/mounts to automount.
# !/bin/sh
while true
do
grep sda /proc/partitions > /dev/zero
if test $? -eq 0; then
grep sda /proc/mounts > /dev/zero
if test $? -eq 1; then
echo "*** mount usbdisk ***"
mount -n -t vfat /dev/sda /mnt/usb
fi
else
echo "*** unmount usbdisk ***"
umount -n /mnt/usb
fi
fi
sleep 1
done
--- Quote Start ---
originally posted by nacide@Jun 8 2006, 03:03 AM
i wrote a little shell script to mount the usb stick, but i dont know if this is the best solution. i wanted to port autofs first but it was to heavyweight.
for the shell script i use /proc/partitions and /proc/mounts to automount.
# !/bin/sh
while true
do
  fi
else
    umount -n /mnt/usb
  fi
fi
sleep 1
done
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16023)
--- quote end ---
--- Quote End ---
hi,
Thank your reply.
I did follow your reply,but it can&#39;t work.
It show "Bad command or file name" for every command which your reply.
Can anyone tell me where i take a mistake?
hi,
Another question:
How to run a shell script in my apps by execve() or other programmes?
Thank you!
zhengkaike,
You need to have the commands that are called like mount, umount, grep, test, echo and sleep in your rootfs.
Maybe it will also work with the busybox versions but I did not test this.
I call the shellscript from the rc script in /etc
for example
automount.sh &
--- Quote Start ---
originally posted by nacide@Jun 13 2006, 04:05 AM
zhengkaike,
you need to have the commands that are called like mount, umount, grep, test, echo and sleep in your rootfs.
maybe it will also work with the busybox versions but i did not test this.
i call the shellscript from the rc script in /etc
for example
automount.sh
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16150)
--- quote end ---
--- Quote End ---
Hi,nacide,
Thank you!
May be my busybox has some bugs,there are many errors when compiled.
I have resolved the problem by using mount() and umount(), it can work successful although it&#39;s not a best method. The code:
--- Quote Start ---
char spe_file[20]="/dev/sda1";
char cur_dir[]="/mnt/usb";
char um_dir[]="/mnt";
char subum_dir[]="usb/";
int main(void)
if(mkdir(cur_dir,O_RDWR)==-1)
//"/mnt/usb"exsit
if(umount(cur_dir)==-1)
printf("erro : umount usb!\n");
exit(1);
chdir(um_dir);
if(rmdir(subum_dir)==-1)
printf("error rmdir %s \n",subum_dir);
exit(1);
printf("umount usb ok!\n");
return 0;
if(mount(spe_file,cur_dir,"vfat",2,(char *)NULL)==-1)
    printf("error :mount");
    exit(1);
printf("mount usb ok!\n");
return 0;
}[/b]
--- Quote End ---
Thank you for your reply again.
