12622 Discussions
problems for download the program to the flash
ep 9, 2006 3:41:02 PM - (??) nios2-flash-programmer: Error opening target hardw
are
the error is that as follow: what's mean?
In order to program flash, you must first create a purpose-built
flash-programming design (i.e. FPGA configuration) and associate it with
your particular board. The Nios development kit is delivered with purpose-bui
lt
flash-programming designs pre-built for several development boards. If you wi
sh
to program flash on your own board, you must first create a flash-programming
design.
The process of creating a flash-programming design for your board is mostly
automated. From a bash-shell, execute this script:
mk_target_board --help
The help-message includes references to other documentation on programming
flash and targeting Nios systems to custom board designs.
- exiting.
WARNING: Default charset GBK not supported, using ISO-8859-1 instead
Use >=5.1 versions of both Quartus II and the Nios II tools. Prior to this version, the flash programmer was more of a pain to use.
Cheers,
- slacker
