I have a project in the 9.1 SP2 Nios II Build Tools Version. It worked quiet good for some time. Now, I'm not able to build or debug (in hardware) the project more than one time. When I start Eclipse (the Build Tool Version) I can make some mods to the source code and I can build the project. BUT when I make some more changes and I would like to build the project a second time I cannot do that because the build process won't start. I also only can clean the BSP but not the C/C++ Project. Building of the BSP is working as expected. I also can debug the project only once in a "workspace session". The next time I try to debug, it isn't doing anything, too. If I close Eclipse and restart it, again I have only one try in either building or debugging the project. This is very anoying and I would like to know what I can do about it. I made one manual addition in the makefile for the C/C++ project: I added a value for APP_CFLAGS_DEFINED_SYMBOLS. Please help me. MaikLink Copied
