12699 Discussions
several elf files in flash
Hi all...
How can I do to write several nios2 applications (elf files) sequentially in flash (without boot_copier) ?
Is there a way to set a address where the programmer starts to write in flash?
You should be able to use elf2flash and specify the offset using the --offset flag - just cat the files together and run use nios2-flash-programmer
--- Quote Start ---
originally posted by jdhar@Mar 29 2006, 07:47 PM
you should be able to use elf2flash and specify the offset using the --offset flag - just cat the files together and run use nios2-flash-programmer
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13905)
--- quote end ---
--- Quote End ---
Hello jdhar, thanks for your answer...
The offset flag wasn&#39;t specified in the elf2flash help..... thanks...
But I couldn&#39;t generate the flash without boot_loader... I want to write several applications in the flash, each one in determined address. My goal is to create a software that copy a determined application to exception area of a processor (there is 3 nios2) to be run. Therefore the boot_loader isn&#39;t necessary, but I don&#39;t know how to generate the .flash without it.
Follow the command that Im using:
elf2flash --silent --input=myprogram --output=./myprogram.flash --sim_optimize=0 --base=0x00000000 --end=0x007fffff --reset=0x00000000 --boot=C:/altera/kits/nios2_51/components/altera_nios2/boot_loader_cfi.srec --ofset=0x00100000
It occurs an error without --boot tag.
Maikon.
Try relocate your elf to binary with nios2-elf-objcopy, then use bin2flash.
Hello...
Thanks for your instructions...
I followed them and I got the .flash without boot loader, but the size of final .flash file (elf=>bin=>flash) is greater that size of old flash file (elf => flash, with boot loader). I analyzed the two flash files and I could see that there were 65 words (32bits) whith 0x00000000 value in bin=>flash file. I think that nios2-elf-objcopy filled some section with 0, but I don&#39;t know what happened...
Any idea?
what is the result size?
Or try strip symbols,
nios2-elf-strip apps nios2-elf-objcopy -O binary apps apps.bin
Hello...
The difference between the file sizes (file_bin->flash - file_elf->flash) is 160 bytes. I tested 5 different examples, and there was the same result.
Follow the result of test with a program:
(The blue area is the data to be writed in flash, the green word is the beginning of boot_loader code, and the red word is the beginning of program code).
[u][b]S012000068656C6C6F5F62696E2E666C61736805
S3250000000004FF7FEF7A3031004C0000C6260300C03A313100260100C004010006344000C6CB
S32500000020045300C6170000C63A6800C000000000000000000000000000000000000000005E
S3250000004000000000000000000000000000000000000000000000000000000000000000009A
S3250000006000000000000000000000000000000000000000000000000000000000000000007A
S3250000008000000000000000000000000000000000000000000000000000000000000000005A
S325000000A000000000000000000000000000000000000000000000000000000000000000003A
S325000000C000000000000000000000000000000000000000000000000000000000000000001A
S325000000E00000000000000000000000000000000000000000000000000000000000000000FA
S325000001000000000000000000000000000000000000000000000000000000000000000000D9
S3250000012000000000000000000000000000000000000000003480C0060400C0DE7440800663
S32500000140049383D67440400004AD6308744080000402B01026038008150000080401400884
</span>
In file_elf->flash, the first word (3A700100) is the first word of boot_loader too. The boot_loader part finishes before the red word (04FF7FEF), wich is the beginning of the program.
In file_bin->flash is writed 11 words and the rest are zeros (528 zeros). After the zeros, two words is missing (orange words in file_elf->flash), and the remaining is the same for two files.
I don&#39;t know why it writed these 528 zeros.
I tryed to use strip, but the result is the same like bin->flash...
