All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
12578 Discussions
sopc-create-header-files : command not found ?
hi,
iam an beginner in fpga soc....
i try the tutorial "my_first_hps_fpga.pdf" ....
so i have an problem to generate header files about embedded command shell...
if i want to execute the bash-file ./generate.sh...
generate.sh
# !/bin/sh
"./hps_fpga.sopcinfo"
--single hps_0.h
--module hps_0
i get this message..
./generate.sh: Line 3: sopc-create-header-files: Commando not found...:oops:
http://www.alteraforum.com/forum/attachment.php?attachmentid=12978&stc=1
i hope somebody can help ... thx..
I have the same error.. I'm trying to create the "sopc-create-header-files" with the sopc builder but my efforts have been unsuccessfully. If you have another clue how we can fix it, please tell me... thx..
Using 16.1 on Windows 10 I was able to run that command using both the SoC and Nios II command prompts. That command is part of Quartus install and you can find the path here: <Quartus install directory>/quartus/sopc_builder/bin/sopc-create-header-files
If anyone else is getting this error, I have figured out the solution.
You have to set the PATH variable in the SoC EDS command shell
The bin folder is located in the path: intelFPGA_lite\16.1\quartus\sopc_builder\bin
you have to add this folder to the PATH environment in the SoC shell
For example:
PATH=/cygdrive/C/intelFPGA_lite/16.1/quartus/sopc_builder/bin:$PATH
You have to change the path to the correct one in your PC ;)
--- Quote Start ---
For example:
PATH=/cygdrive/intelFPGA_lite/16.1/quartus/sopc_builder/bin:$PATH
--- Quote End ---
Hi, I have located the bin folder in my laptop. However, after I add this folder to the PATH environment, it still does not work. The same error occurs. I am using quartus 15.0 web version and my SoC EDS is 17.0 version. Not sure whether different version of quartus and SoC EDS is causing this problem...
For linux :
lauch the Altera embedded script shell
type : $echo $PATH to display the PATH environment variable.
To add a path to this variable, use the command :
export PATH=$PATH:~/intelFPGA_lite/17.1/quartus/sopc_builder/bin
You need to have Quartus installed in addition of the EDS suite.
