uclinux Kernel error ?
Dear all.
I study a linux system on niosII
I have many question.
My status is :
board : de2_115
version : uClinux nios2-linux-20100621. with mmu
At first , my kernel messeage down here.
as you know, my linux system kernel has 3 error. that is uart,jtaguart,flash,,,,,
i don't know , Plz help me.
Starting processor at address 0xC0000000
[root@localhost uClinux-dist]# nios2-terminal
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster [5-1]", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
Linux version 2.6.34-00692-g5bc7853-dirty (root@localhost.localdomain) (gcc version 4.1.2)# 6 Fri Jul 20 23:35:02 KST 2012
bootconsole [early0] enabled
early_console initialized at 0xeb0428b0
Linux/Nios II-MMU
init_bootmem_node(?,0x52d, 0x0, 0x8000)
free_bootmem(0x52d000, 0x7ad3000)
reserve_bootmem(0x52d000, 0x1000)
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Kernel command line:
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
We have 32768 pages of RAM
Memory available: 124608k/5299k RAM, 0k/0k ROM (2033k kernel code, 3265k data)
Hierarchical RCU implementation.
NR_IRQS:32
Calibrating delay loop... 49.76 BogoMIPS (lpj=248832)
Mount-cache hash table entries: 512
NET: Registered protocol family 16
init_BSP(): registering device resources
altera_tse.0: failed to claim resource 2
------------[ cut here ]------------
WARNING: at /home/ted/Alteras/nios2-linux/linux-2.6/drivers/base/core.c:131 device_release+0x80/0x84()
Device 'physmap-flash.0' does not have a release() function, it is broken and must be fixed.
Modules linked in:
Stack from c7c16e5c:
c7c01be0
c0010154
c7c2cd80
c0511b14
fffffff0
00000000
c00101d8
c04eb67c
c7c16e88
00000000
c013caa4
c7c01be0
c050b044
c01144a0
c050b060
c0114448
00000003
c0115460
c050b044
c050b034
c0114374
c02105bc
c02105bc
c013b5bc
c0140d74
c0140e80
00000001
c0140f04
00000000
00000000
c0200d50
deadbeef
c0518230
c0200d7c
c0000210
c00b0000
c0211288
c021142c
c0211244
deadbeef
00000000
deadbeef
c01fe5c8
c0509f6c
c05240b0
00000a00
c0002294
00000000
Call Trace:
[<c000be28>]
[<c00021f8>]
[<c0001074>]
[<c0002288>]
---[ end trace 4eaa2a86a8e2da22 ]---
Device 'altera_uart.0' does not have a release() function, it is broken and must be fixed.
Modules linked in:
c7c01c60
c0010154
c7c2cde0
c0511b14
fffffff0
00000000
c00101d8
c04eb67c
c7c16e88
00000000
c013caa4
c7c01c60
c050af94
c01144a0
c050afb0
c0114448
00000003
c0115460
c050af94
c050af84
c0114374
c02105b8
c02105b8
c013b5bc
c0140d74
c0140e80
00000002
c0140f04
00000000
00000000
c0200d50
deadbeef
c0518230
c0200d7c
c0000210
c00b0000
c0211288
c021142c
c0211244
deadbeef
00000000
deadbeef
c01fe5c8
c0509f6c
c05240b0
00000a00
c0002294
00000000
Call Trace:
[<c000be28>]
[<c00021f8>]
[<c0001074>]
[<c0002288>]
---[ end trace 4eaa2a86a8e2da23 ]---
Device 'jtag_uart.0' does not have a release() function, it is broken and must be fixed.
Modules linked in:
c7c01ce0
c0010154
c7c2ce40
c0511b14
fffffff0
00000000
c00101d8
c04eb67c
c7c16e88
00000000
c013caa4
c7c01ce0
c050aee4
c01144a0
c050af00
c0114448
00000003
c0115460
c050aee4
c050aed4
c0114374
c02105b4
c02105b4
c013b5bc
c0140d74
c0140e80
00000003
c0140f04
00000000
00000000
c0200d50
deadbeef
c0518230
c0200d7c
c0000210
c00b0000
c0211288
c021142c
c0211244
deadbeef
00000000
deadbeef
c01fe5c8
c0509f6c
c05240b0
00000a00
c0002294
00000000
Call Trace:
[<c000be28>]
[<c00021f8>]
[<c0001074>]
[<c0002288>]
---[ end trace 4eaa2a86a8e2da24 ]---
bio: create slab <bio-0> at 0
Switching to clocksource timer
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 243
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
mice: PS/2 mouse device common for all mice
TCP cubic registered
NET: Registered protocol family 17
turn off boot console early0
