user.bashrc script
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif
I just install the Nios II 1.01 and run the shell. Now I got a message as
(You may add a startup script: c:/altera/kits/nios2/user.bashrc)
I cannot find the file, user.bashrc. What will happen if no that file when I run Nios2?
Frigile
No influence on anything.
If the file is provided by the user, the startup script runs it. It is a bit like a DOS batch file.
It can be usefull to go to your project directory on cygwin start.
I used it with NiosI, but after installing the NiosII, my user.bashrc doesn&#39;t work anymore http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
Stefaan
To Stefaan:
Thanks very much. I will begin my travel of design using NIOS II.
Keep contact. My email is xic583@hotmail.com
Frigile http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/rolleyes.gif
