using spi core
I want to use the spi core for adc peripheral AD9253. It has bidirectional SDIO. but spi core in nios has miso and mosi. so how do i tackle this. i want to read and write to the adc registers.
A simple solution is driving SDIO in open collector mode using a tristate i/o buffer and a pull-up resistor.
MOSI is connected to the active low buffer enable port, while the i/o buffer input is hardwired to gnd.
MISO is connected to the same i/o pin.
This way you simply put ones in the spi tx register for the bits you are supposed to receive.
--- Quote Start ---
--- Quote End ---
Hello, sherindeena!
Did You try to make it this way?
Here are another replies to this question:
http://www.alteraforum.com/forum/showthread.php?t=26838
http://www.alteraforum.com/forum/showthread.php?t=38228
Which one is correct?
I am interested because I am about to make the similar connection.
--- Quote Start ---
Hello, sherindeena!
--- Quote End ---
i just left the unused line unconnected. i didnt read back the registers.
