I can not download nios2-linux-20090929.tar . Is there anyone can give it to me? Many thanks.
Hi
You can download the NIOS II-Linux-20090929 from the below link http://www.niosftp.com/pub/linux/nios2-linux-20090929.tar It is working, Size 1.7 Gb- Mark as New
thank you for your reply. But I can not download from that address.I have tried many times,but everytime it shows no ratios.If you have it,can you mail a copy to me ?Thanks a lot.
Hi
Thanks for the Reply but it is not possible to send through mail because the size is 1.7GB that link is working properly so may be you have some issues in you computer so please check- Mark as New
You are so kind.But I have tried many times but failed.I also ask two friends to download it for me ,but failed too.What shall I do?
why no person reply me ? I only want a copy of nios2-linux-20090929.tar.Is there anyone can help me ?Thank you!
Have you tried downloading the file with a download program which can reliably retry and resume on errors? For example, most linux systems have wget which you can use from the command line:
wget http://www.niosftp.com/pub/linux/nios2-linux-20090929.tar- Mark as New
Thank you for your reply.I have also tried many times.
/home/share# wget http://www.niosftp.com/pub/linux/nio...x-20090929.tar --2010-06-10 10:59:41-- http://www.niosftp.com/pub/linux/nio...x-20090929.tar 正在解析主机 www.niosftp.com... 97.74.144.192 正在连接 www.niosftp.com|97.74.144.192|:80... 失败:连接超时。- Mark as New
I have tried many times .But everytime it can not download.If someone can download it from www.nioswiki.com ,please give me a copy.I want it very much.Please help me!Thank you!
Does NIOSWiki work for you at all ?
Without decent access to the NIOWiki the file will not be of much value to you, as all information on how to work with it is to be found in the Wiki. Are you located in China ? There have been several reports that the nioswik (and supposedly many other Wikis) can't be accessed from China due to the government's Internet restrictions. -Michael- Mark as New
You are right.I am Chinese.Is there some methods for me to get a copy of nios2-linux-20090929.tar?Thank you for your reply.
As said: the file alone will be not be of much value for you if you can't read the Wiki.
Maybe there is some kind of encrypting proxy out there to overcome the Firewall that banns dangerous websites, but I have no idea if/how this is possible; and of course doing so might be illegal. -Michael- Mark as New
I am sad! I need it very much.
My situation is the same as rubylc and can not download nios2-linux-20090929.tar, http download or wget download methods have been tried, has not been successful, I do not think the reason is due to government control, that may be caused by the failure of network connections to niosftp server failure, this is my guess, because government control has never been carried out on the technology Web site, you can try again a few days, now do not have access to http://www.niosftp.com , nioswiki can access.
Hi masters , I have the identical problem as the poster. As someone said, I am in china, ****ing damn internet restriction, We can not download the file above, Is anyone to give help for us inside the GFW. or put that tar file onto another address on the internet
Can you access the NiosWiki at all ? If not the file will not be very helpful.
Maybe a mirror of NiosWiki should be set up... -Michael- Mark as New
Yes, I can access the NiosWiki, but I could not find the address for download on the web of it. I have tried it many times until today. Meanwhile, I found the website niosftp was transfered into alteraforum. the responsive message was like this, The connection to the server was reset while the page was loading. would Mr mschnell like to help us ? many thanks for you and best regard. We only want to a website link to the resource which can be really downloaded.
please download the new tar ball, see another post.
http://alteraforum.com/forum/showpost.php?p=94092&postcount=3 - Hippo- Mark as New
thanks to hippo so much, a really smart and handsome man ~~~~oooo
cool!I met the same problem,but I have solved it successfully! many thanks to you!
