OpenCL* for CPU
Bug in OpenCL kernel builder on Intel HD Graphics
Alexander_Karsakov
Hello.
I found a curious bug in kernel builder of Intel OpenCL SDK (Version 2013 R3 64-bit) when it executes on Intel HD Graphics 4600 (Core i5 4570).
I write following kernel:
#define cn 1
__local uchar val1; val1 = 19;
__local uchar val2; val2 = 18;
__local uchar val3; val3 = 9;
__local uchar res; res = 255;
for (int c = 0; c < cn; ++c)
    if ( val2 > val1 || val3 < val1 )
            res = 0;
            break;
This is a simplified version of a piece of code of InRange function from OpenCV library.
Correct value 'res' variable is 0, but I have 255. On other platforms (Intel CPU, NVIDIA, AMD) this code works correct. If remove 'break' this code works fine on all platforms.
HD Graphics driver version: 9.18.10.3257
Raghupathi_M_Intel
I verified that indeed the 3257 driver has the bug. Please update the driver and let us know.
Raghu
Raghupathi_M_Intel
Hi Alexander,
The driver you are using is old. It is possible that there is a bug in that version, but I tested this on the latest driver on downloadcenter.intel.com (10.18.10.3345) and I get the correct result. Is it possible for you to update the driver and try again?
Raghu
Raghupathi_M_Intel
Raghu
Alexander_Karsakov
Hi Raghu,
I installed new version of HD graphics driver and this code works correctly.
Thanks a lot!
