OpenCL* for CPU
1719 Discussions
Couldn't create a context, clCreateContextFromType() returned 'CL_DEVICE_NOT_AVAILABLE'.
wei__ran
My OS:  ubuntu 18.04.1
My CPU: Intel(R) Xeon(R) CPU E5-2609 v4 @ 1.70GHz
The information of clinfo
Number of platforms                               2
  Platform Name                                   NVIDIA CUDA
  Platform Vendor                                 NVIDIA Corporation
  Platform Version                                OpenCL 1.2 CUDA 10.2.159
  Platform Profile                                FULL_PROFILE
  Platform Extensions                             cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_nv_create_buffer cl_khr_int64_base_atomics cl_khr_int64_extended_atomics
  Platform Extensions function suffix             NV
  Platform Name                                   Intel(R) CPU Runtime for OpenCL(TM) Applications
  Platform Vendor                                 Intel(R) Corporation
  Platform Version                                OpenCL 2.1 LINUX
  Platform Extensions                             cl_khr_icd cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_depth_images cl_khr_3d_image_writes cl_intel_exec_by_local_thread cl_khr_spir cl_khr_fp64 cl_khr_image2d_from_buffer cl_intel_vec_len_hint
  Platform Host timer resolution                  1ns
  Platform Extensions function suffix             INTEL
Number of devices                                 1
  Device Name                                     GeForce RTX 2080 Ti
  Device Vendor                                   NVIDIA Corporation
  Device Vendor ID                                0x10de
  Device Version                                  OpenCL 1.2 CUDA
  Driver Version                                  440.82
  Device OpenCL C Version                         OpenCL C 1.2
  Device Type                                     GPU
  Device Topology (NV)                            PCI-E, 81:00.0
  Device Profile                                  FULL_PROFILE
  Device Available                                Yes
  Compiler Available                              Yes
  Linker Available                                Yes
  Max compute units                               68
  Max clock frequency                             1545MHz
  Compute Capability (NV)                         7.5
  Device Partition                                (core)
    Max number of sub-devices                     1
    Supported partition types                     None
  Max work item dimensions                        3
  Max work item sizes                             1024x1024x64
  Max work group size                             1024
  Preferred work group size multiple              32
  Warp size (NV)                                  32
  Preferred / native vector sizes
    char                                                 1 / 1
    short                                                1 / 1
    int                                                  1 / 1
    long                                                 1 / 1
    half                                                 0 / 0        (n/a)
    float                                                1 / 1
    double                                               1 / 1        (cl_khr_fp64)
  Half-precision Floating-point support           (n/a)
  Single-precision Floating-point support         (core)
    Denormals                                     Yes
    Infinity and NANs                             Yes
    Round to nearest                              Yes
    Round to zero                                 Yes
    Round to infinity                             Yes
    IEEE754-2008 fused multiply-add               Yes
    Support is emulated in software               No
    Correctly-rounded divide and sqrt operations  Yes
  Double-precision Floating-point support         (cl_khr_fp64)
    Denormals                                     Yes
    Round to zero                                 Yes
  Address bits                                    64, Little-Endian
  Global memory size                              11554717696 (10.76GiB)
  Error Correction support                        No
  Max memory allocation                           2888679424 (2.69GiB)
  Unified memory for Host and Device              No
  Integrated memory (NV)                          No
  Minimum alignment for any data type             128 bytes
  Alignment of base address                       4096 bits (512 bytes)
  Global Memory cache type                        Read/Write
  Global Memory cache size                        2228224 (2.125MiB)
  Global Memory cache line size                   128 bytes
  Image support                                   Yes
    Max number of samplers per kernel             32
    Max size for 1D images from buffer            268435456 pixels
    Max 1D or 2D image array size                 2048 images
    Max 2D image size                             32768x32768 pixels
    Max 3D image size                             16384x16384x16384 pixels
    Max number of read image args                 256
    Max number of write image args                32
  Local memory type                               Local
  Local memory size                               49152 (48KiB)
  Registers per block (NV)                        65536
  Max number of constant args                     9
  Max constant buffer size                        65536 (64KiB)
  Max size of kernel argument                     4352 (4.25KiB)
  Queue properties
    Out-of-order execution                        Yes
    Profiling                                     Yes
  Prefer user sync for interop                    No
  Profiling timer resolution                      1000ns
  Execution capabilities
    Run OpenCL kernels                            Yes
    Run native kernels                            No
    Kernel execution timeout (NV)                 No
  Concurrent copy and kernel execution (NV)       Yes
    Number of async copy engines                  3
  printf() buffer size                            1048576 (1024KiB)
  Built-in kernels
  Device Extensions                               cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_nv_create_buffer cl_khr_int64_base_atomics cl_khr_int64_extended_atomics
Number of devices                                 1
  Device Name                                     Intel(R) Xeon(R) CPU E5-2609 v4 @ 1.70GHz
  Device Vendor                                   Intel(R) Corporation
  Device Vendor ID                                0x8086
  Device Version                                  OpenCL 2.1 (Build 0)
  Driver Version                                  18.1.0.0920
  Device OpenCL C Version                         OpenCL C 2.0
  Device Type                                     CPU
  Max compute units                               16
  Max clock frequency                             1700MHz
    Max number of sub-devices                     16
    Supported partition types                     by counts, equally, by names (Intel)
  Max work item sizes                             8192x8192x8192
  Max work group size                             8192
  Preferred work group size multiple              <getWGsizes:671: create context : error -2>
  Max sub-groups per work group                   1
    char                                                 1 / 32
    short                                                1 / 16
    int                                                  1 / 8
    long                                                 1 / 4
    half                                                 0 / 0        (n/a)
    float                                                1 / 8
    double                                               1 / 4        (cl_khr_fp64)
    Denormals                                     Yes
    Round to zero                                 No
    Round to infinity                             No
    IEEE754-2008 fused multiply-add               No
    Correctly-rounded divide and sqrt operations  No
    Denormals                                     Yes
    Round to zero                                 Yes
  Global memory size                              67420585984 (62.79GiB)
  Max memory allocation                           16855146496 (15.7GiB)
  Unified memory for Host and Device              Yes
  Shared Virtual Memory (SVM) capabilities        (core)
    Coarse-grained buffer sharing                 Yes
    Fine-grained buffer sharing                   Yes
    Fine-grained system sharing                   Yes
    Atomics                                       Yes
  Alignment of base address                       1024 bits (128 bytes)
  Preferred alignment for atomics
    SVM                                           64 bytes
    Global                                        64 bytes
    Local                                         0 bytes
  Max size for global variable                    65536 (64KiB)
  Preferred total size of global vars             65536 (64KiB)
  Global Memory cache size                        262144 (256KiB)
  Global Memory cache line size                   64 bytes
  Image support                                   Yes
    Max number of samplers per kernel             480
    Max size for 1D images from buffer            1053446656 pixels
    Base address alignment for 2D image buffers   64 bytes
    Pitch alignment for 2D image buffers          64 pixels
    Max 2D image size                             16384x16384 pixels
    Max 3D image size                             2048x2048x2048 pixels
    Max number of read image args                 480
    Max number of write image args                480
    Max number of read/write image args           480
  Max number of pipe args                         16
  Max active pipe reservations                    16383
  Max pipe packet size                            1024
  Local memory type                               Global
  Local memory size                               32768 (32KiB)
  Max number of constant args                     480
  Max constant buffer size                        131072 (128KiB)
  Max size of kernel argument                     3840 (3.75KiB)
  Queue properties (on host)
    Profiling                                     Yes
    Local thread execution (Intel)                Yes
  Queue properties (on device)
    Profiling                                     Yes
    Preferred size                                4294967295 (4GiB)
    Max size                                      4294967295 (4GiB)
  Max queues on device                            4294967295
  Max events on device                            4294967295
  Profiling timer resolution                      1ns
    Run native kernels                            Yes
    Sub-group independent forward progress        No
    IL version                                    SPIR-V_1.0
    SPIR versions                                 1.2
  Built-in kernels
  Device Extensions                               cl_khr_icd cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_depth_images cl_khr_3d_image_writes cl_intel_exec_by_local_thread cl_khr_spir cl_khr_fp64 cl_khr_image2d_from_buffer cl_intel_vec_len_hint
NULL platform behavior
  clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...)  No platform
  clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...)   No platform
  clCreateContext(NULL, ...) [default]            No platform
  clCreateContext(NULL, ...) [other]              Success [NV]
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT)  No platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU)  No platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM)  Invalid device type for platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL)  No platform
    NOTE:    your OpenCL library only supports OpenCL 2.0,
        but some installed platforms support OpenCL 2.1.
        Programs using 2.1 features may crash
        or behave unexepectedly
When I run the example in ocl-tools-walkthrough-20181221.tar.gz , it failed ,and the Error:
Selected device type is CL_DEVICE_TYPE_CPU
Number of available platforms: 2
Selected platform: Intel(R) CPU Runtime for OpenCL(TM) Applications
some information of cat /proc/cpuinfo
 processor    : 0
vendor_id    : GenuineIntel
cpu family    : 6
model        : 79
model name    : Intel(R) Xeon(R) CPU E5-2609 v4 @ 1.70GHz
stepping    : 1
microcode    : 0xb000038
cpu MHz        : 1197.112
cache size    : 20480 KB
physical id    : 0
siblings    : 8
core id        : 0
cpu cores    : 8
apicid        : 0
initial apicid    : 0
fpu        : yes
fpu_exception    : yes
cpuid level    : 20
wp        : yes
flags        : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid dca sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb cat_l3 cdp_l3 invpcid_single pti intel_ppin ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 hle avx2 smep bmi2 erms invpcid rtm cqm rdt_a rdseed adx smap intel_pt xsaveopt cqm_llc cqm_occup_llc cqm_mbm_total cqm_mbm_local dtherm arat pln pts md_clear flush_l1d
bugs        : cpu_meltdown spectre_v1 spectre_v2 spec_store_bypass l1tf mds swapgs
bogomips    : 3392.31
clflush size    : 64
cache_alignment    : 64
address sizes    : 46 bits physical, 48 bits virtual
power management:
Ben_A_Intel
This is strange - I haven't seen a CL_DEVICE_NOT_AVAILABLE error like this before, and I can't think of a reason why this would be occurring.
It's even weirder since the output from clinfo indicates that the device is available.
Is the issue specific to this sample, or do you see it with other samples, also?
Ben_A_Intel
If it's helpful, I found a few older forum threads that describe similar issues and have either more information or things to try:
https://software.intel.com/en-us/forums/opencl/topic/632440
https://software.intel.com/en-us/forums/opencl/topic/806886
