I have been using the HD4600.
After version up of the driver,
Changes in the outcome of OpenCL occurred.
Is there a way to avoid?
(attached the resources)
· OpenCL SDK
Intel SDK for OpenCL Applications 2016
· GPU driver version
before: 10.18.10.3496 (2014/03/11)
after: 10.18.14.4264 (2015/08/04)
・clCreateContext()
clGetDeviceIDs() -
cl_device_type device_type = CL_DEVICE_TYPE_GPU; // (Intel(R) HD Graphics 4600)
・clBuildProgram()
const char *options = NULL
1. Have you tried https://downloadcenter.intel.com/download/25588/Intel-Graphics-Driver-for-Windows-7-8-1-15-36- driver?
2. Could you please provide a complete example and steps to reproduce?
3. What did you get before? What are you getting now?
4. What are the sizes of your input/output buffers? What is the size of your enqueue? global/local sizes? Complete example would help a lot!
BTW, on the latest and greatest production driver (4380) on Windows 10, I am getting the results I expect from your kernel. The assembly for your kernel looks correct as well. So it could be that what you got previously is in error.
Dear Robert,
Thank you kind reply
I tried. But the results did not change
Sorry
Upload all of the data
Please check the readme.txt
Now I can not update to Windows10. However, there are plans to update
Please let me questions again.
It is a new program and run results
Problem due has occurred in local_work_size
OS:Windows7
GPU:Intel(R) HD Graphics 4600
Driver:10.18.14.4332
OpenCL SDK: 2016
OpenCL Code Builder:6.0.0.1049
#include "stdafx.h" #include <Windows.h> #ifdef __APPLE__ #include <OpenCL/opencl.h> #else #include "CL/cl.h" #endif cl_device_id g_DeviceID = 0; cl_context g_Context = 0; cl_command_queue g_CommandQueue = 0; cl_program clProgram = 0; cl_kernel clKernel = 0; cl_mem g_InputBinBuf = 0; cl_mem g_OutputBuf = 0; const char* DRIVER_NAME = "Intel(R) HD Graphics 4600"; #define INPUT_BIN_WIDTH (8) #define INPUT_BIN_HEIGHT (4) #define DATA_NUM (INPUT_BIN_WIDTH*INPUT_BIN_HEIGHT) #define DATA_SIZE (DATA_NUM*4) // Test Data unsigned int InputData[DATA_NUM] = { 0, 0, 0, 0, 0, 0, 0, 0, 0x00000102, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }; // Kernel Code const char* kernel_code = "" "__kernel void TestKernel( __global unsigned int* oBuffer, \n" " const __global unsigned int* iRgbaImage, \n" " const int iImageWidth \n" ") \n" "{ \n" " int gx = get_global_id(0); \n" " int gy = get_global_id(1); \n" " \n" " unsigned int Input; \n" " unsigned int result; \n" " int pos; \n" " \n" " pos = gy * iImageWidth + gx; // ReadAddress \n" " Input = iRgbaImage[pos]; // TargetData \n" " \n" " result = Input & 0xff; \n" " if ( ((Input>>8)&0xff) != 0){ \n" " result = ((Input>>8)&0xff) + (Input&0xff); \n" " } \n" " \n" " oBuffer[pos] = result; \n" "} \n"; //----------------------------------- // Init Resource //----------------------------------- void Init(void) { cl_uint numPlatforms; cl_int ret; // CreateOpenCL ret = clGetPlatformIDs(0, NULL, &numPlatforms); cl_platform_id *platform_id = new cl_platform_id[numPlatforms]; cl_device_id device_id; ret = clGetPlatformIDs(numPlatforms, platform_id, NULL); static const int INFO_MAX = 128; char device_name[INFO_MAX]; for(cl_uint i = 0; i < numPlatforms; ++i){ clGetDeviceIDs( platform_id, CL_DEVICE_TYPE_GPU, 1, &device_id, NULL); clGetDeviceInfo( device_id, CL_DEVICE_NAME, INFO_MAX, device_name, NULL); if(NULL != strstr(device_name, DRIVER_NAME)){ g_DeviceID = device_id; break; } } if(g_DeviceID == 0){ printf("no match driver"); exit(0); } g_Context = clCreateContext( NULL, 1, &g_DeviceID, NULL, NULL, NULL); g_CommandQueue = clCreateCommandQueue(g_Context, g_DeviceID, 0, NULL); delete[] platform_id; size_t source_size = strlen(kernel_code); clProgram = clCreateProgramWithSource(g_Context, 1, (const char **)&kernel_code, (const size_t *)&source_size, &ret); ret = clBuildProgram(clProgram, 1, &g_DeviceID, NULL, NULL, NULL); clKernel = clCreateKernel(clProgram, "TestKernel", &ret); // Create Buffer g_InputBinBuf = clCreateBuffer(g_Context, CL_MEM_READ_WRITE, DATA_SIZE, NULL, &ret); g_OutputBuf = clCreateBuffer(g_Context, CL_MEM_READ_WRITE, DATA_SIZE, NULL, &ret); } //----------------------------------- // Call Kernel //----------------------------------- void NDRangeKernel(const UINT32* image, size_t* local_work_size) { // Copy InputBin To g_InputBinBuf clEnqueueWriteBuffer(g_CommandQueue, g_InputBinBuf, CL_TRUE, 0, DATA_SIZE, image, 0, NULL, NULL); // Kernl int data_width = INPUT_BIN_WIDTH; clSetKernelArg(clKernel, 0, sizeof(cl_mem), (void*)&g_OutputBuf); // output clSetKernelArg(clKernel, 1, sizeof(cl_mem), (void*)&g_InputBinBuf); // input clSetKernelArg(clKernel, 2, sizeof(int), (void *)&data_width); size_t global_item_size[] = {INPUT_BIN_WIDTH, INPUT_BIN_HEIGHT}; clEnqueueNDRangeKernel( g_CommandQueue, // clKernel, // 2, // dim NULL, // global_work_offset global_item_size, local_work_size, 0, NULL, NULL ); } //----------------------------------- // Clear Resource //----------------------------------- void End(void) { clReleaseMemObject(g_InputBinBuf); clReleaseMemObject(g_OutputBuf); clReleaseKernel(clKernel); clReleaseProgram(clProgram); clFlush(g_CommandQueue); clFinish(g_CommandQueue); clReleaseCommandQueue(g_CommandQueue); clReleaseContext(g_Context); } //================================================ // main //================================================ int _tmain(int argc, _TCHAR* argv[]) { //------------- // Init Resource Init(); //------------- // Test Main UINT32 ResultBuf[2][DATA_NUM]; // NDRangeKernel LocalWork=NULL NDRangeKernel(InputData, NULL); clEnqueueReadBuffer(g_CommandQueue, g_OutputBuf, CL_TRUE, 0, DATA_SIZE, ResultBuf[0], 0, NULL, NULL); #if 0 // another error case NDRangeKernel(InputData, NULL); size_t full_item_size[] = {INPUT_BIN_WIDTH, INPUT_BIN_HEIGHT}; NDRangeKernel(InputData, full_item_size); clEnqueueReadBuffer(g_CommandQueue, g_OutputBuf, CL_TRUE, 0, DATA_SIZE, ResultBuf[0], 0, NULL, NULL); #endif // NDRangeKernel LocalWork={1,1} size_t local_item_size[] = {1,1}; NDRangeKernel(InputData, local_item_size); clEnqueueReadBuffer(g_CommandQueue, g_OutputBuf, CL_TRUE, 0, DATA_SIZE, ResultBuf[1], 0, NULL, NULL); //------------- // Print Result printf("LocalWork=NULL\n"); for(int i = 0; i < INPUT_BIN_HEIGHT; i++){ for(int j = 0; j < INPUT_BIN_WIDTH; j++) printf("%d ",ResultBuf[0][i*INPUT_BIN_WIDTH + j]); printf("\n"); } printf("\n"); printf("LocalWork={1,1}\n"); for(int i = 0; i < INPUT_BIN_HEIGHT; i++){ for(int j = 0; j < INPUT_BIN_WIDTH; j++) printf("%d ",ResultBuf[1][i*INPUT_BIN_WIDTH + j]); printf("\n"); } printf("\n"); //------------- // Clear Resource End(); system("pause"); return 0; }
result
LocalWork=NULL
0 0 0 0 0 0 0 0
1 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
LocalWork={1,1}
0 0 0 0 0 0 0 0
3 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
