OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1686 Discussions
Does HD5300 support the 'new globally coherent memory type' mentioned in Gen8.pdf. How does application use it?
laura_t_
I have a HD5300 platform at hand.
Does HD5300 support the 'new globally coherent memory type' mentioned in 'Compute Architecture of Intel Processor Graphics Gen8.pdf'?
If yes, then how to write the application to take advantage of this coherent memory type?
Robert_I_Intel
Laura,
The document talks about fine grained buffer SVM. Unfortunately, HD5300 supports only Coarse grained buffer SVM. The globally coherent memory is supported on the HD5500+ chips with January 15, 2015 drivers. After creating an Intel OpenCL 2.0 device, you should be able to query for and find:
  • CL_DEVICE_SVM_COARSE_GRAIN_BUFFER
  • CL_DEVICE_SVM_FINE_GRAIN_BUFFER
  • CL_DEVICE_SVM_FINE_GRAIN_SYSTEM
  • CL_DEVICE_SVM_ATOMICS
Could you run CPU-Z and provide a CPU and Graphics tabs screenshots? If you have E0/F0 stepping, fine grained SVM might work with the latest driver.
Robert
