OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1730 Discussions
Error:clGetDeviceInfo (-30) AMD Catalyst 11.8 Preview
zkleo
Good evening.
After you install the AMD Driver 11.8 for Windows Preview Cayalyst 7 64-bit (http://support.amd.com/us/kbarticles/Pages/Catalyst118DriverPreview.aspx )
I found errors in the software Intel SDK OpenCL.
In practice using the tools from the command prompt clinfo AMD have this result:
First installing the runtime OpenCL Intel
Round to + infinity and there: Yes
IEEE754-2008 fused multiply-add: Yes
Cache type: None
Cache line size: 0
Cache size: 0
Global memory size: 1073741824
Constant buffer size: 65536
Max number of args constant: 8
Local memory type: Scratchpad
Local memory size: 32768
Preferred multiple kernel work group size: 64
Error correction support: 0
Unified memory for Host and Device: 0
Profiling Timer resolution: 1
Device endianess Little
Available: Yes
Compiler available: Yes
Execution capabilities:
Execute OpenCL kernels: Yes
Execute native function: No
Queue properties:
Out-of-Order: No
Profiling: Yes
Platform ID: 000007FEEA69D348
Vendor: Advanced Micro Devices, Inc.
Device OpenCL C version: OpenCL C 1.1
Driver version: 01/04/1523 CAL (VM)
Profile: FULL_PROFILE
Version: 1.1 OpenCL AMD-APP-SDK v2.5 (70
9.2)
Extensions: cl_khr_fp64 cl_amd_fp64 cl_khr_
global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int3
2_base_atomics cl_khr_local_int32_extended_atomics cl_khr_3d_image_writes cl_khr
_byte_addressable_store cl_khr_gl_sharing cl_ext_atomic_counters_32 cl_amd_devic
e_attribute_query cl_amd_vec3 cl_amd_printf cl_amd_media_ops cl_amd_popcnt cl_kh
r_d3d10_sharing
Device Type: CL_DEVICE_TYPE_GPU
Device ID: 4098
Board name: ATI Radeon HD 5900 Series
Compute max units: 20
Max dimensions work items: 3
Max work items [0]: 256
Max work items [1]: 256
Max work items [2]: 256
Max work group size: 256
Preferred vector char width: 16
Preferred short vector width: 8
Preferred vector int width: 4
Preferred long vector width: 2
Preferred vector float width: 4
Preferred vector double width: 2
Native char vector width: 16
Native vector short width: 8
Native vector int width: 4
Native long vector width: 2
Native vector float width: 4
Native vector double width: 2
Max clock frequency: 725Mhz
Address bits: 32
Max memory allocation: 536870912
Image support: Yes
Max number of images read arguments: 128
Max number of images write arguments: 8
2D image max width: 8192
2D image max height: 8192
3D max image width: 2048
3D max image height: 2048
3D image depth max: 2048
Within kernel samplers Max: 16
Max size of the kernel argument: 1024
Alignment (bits) of the basic address: 32768
Minimum alignment (bytes) for Any datatype: 128
Single precision floating point capability
Denorms: No
Quiet NaNs: Yes
Round to nearest even: Yes
Round to Zero: Yes
Cache type: None
Cache line size: 0
Cache size: 0
Available: Yes
Queue properties:
Out-of-Order: No
Profiling: Yes
9.2)
r_d3d10_sharing
Device ID: 4098
Address bits: 32
Image support: Yes
Denorms: No
Quiet NaNs: Yes
Round to Zero: Yes
Cache type: None
Cache line size: 0
Cache size: 0
Available: Yes
Queue properties:
Out-of-Order: No
Profiling: Yes
9.2)
r_d3d10_sharing
Device Type: CL_DEVICE_TYPE_CPU
Device ID: 4098
Board name:
Compute max units: 4
Max work items [0]: 1024
Max work items [1]: 1024
Max work items [2]: 1024
Max work group size: 1024
Preferred vector double width: 0
Native vector double width: 0
Max clock frequency: 3166Mhz
Address bits: 64
Max memory allocation: 2147483648
Image support: Yes
Max size of the kernel argument: 4096
Alignment (bits) base address of: 1024
Denorms: Yes
Quiet NaNs: Yes
Round to Zero: Yes
IEEE754-2008 fused multiply-add: No
Cache type: Read / Write
Cache line size: 64
Cache size: 32768
Global memory size: 8589017088
Local Memory Type: Global
Preferred multiple kernel work group size: 1
Unified memory for Host and Device: 1
Profiling timer resolution: 323
Available: Yes
Execute native function: Yes
Queue properties:
Out-of-Order: No
Profiling: Yes
Name: Intel Core 2 Extreme CPU
X9650@3.00GHz
Vendor: GenuineIntel
Driver version: 2.0
9.2)
2_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_
khr_int64_extended_atomics cl_khr_byte_addressable_store cl_khr_gl_sharing cl_ex
t_device_fission cl_amd_device_attribute_query cl_amd_vec3 cl_amd_media_ops cl_a
md_popcnt cl_amd_printf cl_khr_d3d10_sharing
After installing the runtime OpenCL Intel
Quiet NaNs: Yes
Round to Zero: Yes
Cache type: None
Cache line size: 0
Cache size: 0
Available: Yes
Queue properties:
Out-of-Order: No
Profiling: Yes
Platform ID: 000007FEE8DDD348
9.2)
r_d3d10_sharing
Device ID: 4098
Address bits: 32
Image support: Yes
Denorms: No
Quiet NaNs: Yes
Round to Zero: Yes
Cache type: None
Cache line size: 0
Cache size: 0
Available: Yes
Queue properties:
Out-of-Order: No
Profiling: Yes
9.2)
r_d3d10_sharing
Device ID: 4098
Address bits: 32
Image support: Yes
Denorms: No
Quiet NaNs: Yes
Round to Zero: Yes
Cache type: None
Cache line size: 0
Cache size: 0
Available: Yes
Queue properties:
Out-of-Order: No
Profiling: Yes
9.2)
r_d3d10_sharing
Device ID: 4098
Board name:
Address bits: 64
Image support: Yes
Denorms: Yes
Quiet NaNs: Yes
Round to Zero: Yes
Cache line size: 64
Cache size: 32768
Available: Yes
Queue properties:
Out-of-Order: No
Profiling: Yes
X9650@3.00GHz
Driver version: 2.0
9.2)
Platform Name: Intel OpenCL
Number of devices: 1
Device ID: 32902
ERROR: clGetDeviceInfo (-30)
Evgeny_F_Intel
It might be some contention on ICD (OpenCL.dll)level.
The ICD your are using probably comming from AMD and located in System32.
Our binariesare checked forcompatability before the release.
Since, you are trying AMD preview version of drivers, I would advice you to contact AMD support.
zkleo
Ok I solved for good by cleaning up the logs.
I have uninstalled and reinstalled all software.
Time and 'ok. It runs everything perfect.
Thanks for the suggestion OpenCL.dll in System32.
It made me suspicious, so I cleaned and reinstalled.
Evgeny_F_Intel
Good to here that your problem was resolved.
Small question. After removing OpenCL.dll from System32, did you reinstall all packages or just Intel SDK?
zkleo
1) I removed OpenCL.dll by System 32 .
2) Reinstalled runtimes AMD and Intel.
Here 'the results
Address bits: 32
Image support: Yes
Denorms: No
Quiet NaNs: Yes
Round to Zero: Yes
Cache type: None
Cache line size: 0
Cache size: 0
Available: Yes
Queue properties:
Out-of-Order: No
Profiling: Yes
Platform ID: 000007FEE851D348
9.2)
r_d3d10_sharing
Device ID: 4098
Address bits: 32
Image support: Yes
Denorms: No
Quiet NaNs: Yes
Round to Zero: Yes
Cache type: None
Cache line size: 0
Cache size: 0
Available: Yes
Queue properties:
Out-of-Order: No
Profiling: Yes
9.2)
r_d3d10_sharing
Device ID: 4098
Address bits: 64
Image support: Yes
Denorms: Yes
Quiet NaNs: Yes
Round to Zero: Yes
Cache line size: 64
Cache size: 32768
Available: Yes
Queue properties:
Out-of-Order: No
Profiling: Yes
X9650@3.00GHz
Driver version: 2.0
9.2)
Device ID: 32902
Max clock frequency: 3000MHz
Address bits: 64
Max memory allocation: 2147254272
Image support: Yes
Max number of images write arguments: 128
Within samplers max kernel: 128
Denorms: Yes
Quiet NaNs: Yes
Round to Zero: No
Round to + infinity and there: No
Cache line size: 64
Cache size: 6291456
Constant buffer size: 131072
Max number of args constant: 128
Preferred multiple kernel work group size: 16
Available: Yes
Queue properties:
Out-of-order: Yes
Profiling: Yes
Platform ID: 0000000007797460
X9650@3.00GHz
Vendor: Intel Corporation
Driver version: 1.1
Version: OpenCL 1.1 (Build 13785.5219)
Extensions: cl_khr_fp64 cl_khr_global_int32
_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomi
cs cl_khr_local_int32_extended_atomics cl_khr_gl_sharing cl_khr_byte_addressable
_store cl_intel_printf cl_ext_device_fission
