OpenCL* for CPU
Getting Started in Linux with Intel® SDK for OpenCL™ Applications
ameln3
I followed the instructions here: https://software.intel.com/en-us/articles/sdk-for-opencl-gsg
I have successfully completed all the steps listed above. When running neon.3 eclipse I have got the following message:
"Cannot get platform list:
Could not load required libraries; please make sure to set the correct path under the Code Builder for OpenCL preference page."
python sys_analyzer -v outputs:
Hardware readiness checks:
 [ OK ] Processor name: Intel(R) Core(TM) i3-4010U CPU @ 1.70GHz
 [ INFO ] Intel Processor
 [ INFO ] Processor brand: Core
 [ INFO ] Processor arch: Haswell
OS readiness checks:
 [ INFO ] GPU PCI id     : 0A16
 [ INFO ] GPU description: HSW ULT GT2 mobile
 [ OK ] GPU visible to OS
 [ INFO ] no nomodeset in GRUB cmdline (good)
 [ INFO ] Linux distro   : Ubuntu 16.04
 [ INFO ] Linux kernel   : 4.13.0-36-generic
 [ INFO ] glibc version  : 2.23
 [ INFO ] Linux distro suitable for Generic install
 [ INFO ] gcc version    : 20160609 (>=4.8.2 suggested)
Media Server Studio Install:
 [ OK ] user in video group
 [ OK ] libva.so.1 found
 [ ERROR ] libva not loading Intel iHD
 [ OK ] vainfo reports valid codec entry points
 [ INFO ] i915 driver in use by Intel video adapter
 [ OK ] /dev/dri/renderD128 connects to Intel i915
Component Smoke Tests:
 [ ERROR ] no Media SDK include files.  Are Intel components installed?
 [ OK ] OpenCL check:platform:Intel(R) OpenCL GPU OK CPU OK
platform:Experimental OpenCL 2.1 CPU Only Platform GPU OK CPU OK
I also successfully able to run
ioc64 -input=simpleAdd.cl -asm
What is missing? Do I have to install anything else?
Thank you...
Michael_C_Intel1
Hi AndreyM,
Thanks for the detailed feedback.
This issue appears to addressed in the release notes and called out as the libcurl dependency prereq in the example set up guide. References:
If this doesn't map to your issue please attach a screen shot of the error. Either way, can you let us know how it goes?
-MichaelC
ameln3
Thank you!!!
Let me digest your response :-).
Andrey M.
ameln3
Dear Michael,
thank you for the updates.
It worked.
Andrey M.
Michael_C_Intel1
Great deal... thanks for letting us know.
