OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1730 Discussions
Missing the double precision extension (cl_khr_fp64) on a Ubuntu 14.04 virtualbox running within Windows 7 using Core i7 2620M
Gu_S_
I can find the cl_khr_fp64 extension, required for double precision, on a Ubuntu 14.04 running on Amazon EC2 using Intel Xeon and Intel Code Builder for OpenCL API 2015 for Ubuntu:
OS name: Linux
Release:3.13.0-52-generic
Version:#86-Ubuntu SMP Mon May 4 04:32:59 UTC 2015
Machine:x86_64
Platform name = Intel(R) OpenCL
Platform version = OpenCL 1.2 LINUX
Platform extensions = cl_khr_icd cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_depth_images cl_khr_3d_image_writes cl_intel_exec_by_local_thread cl_khr_spir cl_khr_fp64
Device name =       Intel(R) Xeon(R) CPU E5-2670 v2 @ 2.50GHz
Device version = OpenCL 1.2 (Build 43)
Device global memory size= 1040732160
Device available? Yes
Device extensions= cl_khr_icd cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_depth_images cl_khr_3d_image_writes cl_intel_exec_by_local_thread cl_khr_spir cl_khr_fp64
Following double precision features supported:
  INF and NaN values
  Denormalized numbers
  Round To Nearest Even mode
  Round To Infinity mode
  Round To Zero mode
  Floating-point multiply-and-add operation
I can also see that extension for Core i7-2620M:
But I dont see that extension on my home system with Ubuntu 14.04 running as a VirtualBox machine within Windows 7 using Core i7-2620M and the same Intel Code Builder for OpenCL API 2015 for Ubuntu, as the one on Amazon EC2:
OS name: Linux
Release:3.13.0-53-generic
Version:#89-Ubuntu SMP Wed May 20 10:34:39 UTC 2015
Machine:x86_64
Device name =        Intel(R) Core(TM) i7-2620M CPU @ 2.70GHz
Device global memory size= 3156189184
Double precision not supported
How can I get that extension for my home system above?
Thanks in advance!
PS: Checked for double precision using...
cl_device_fp_config flag;
ret = clGetDeviceInfo(device_id, CL_DEVICE_DOUBLE_FP_CONFIG, sizeof(flag), &flag, NULL);
if (!flag)
	printf("Double precision not supported \n\n");
else
	printf("Following double precision features supported:\n");
if(flag & CL_FP_INF_NAN)
	printf("  INF and NaN values\n");
if(flag & CL_FP_DENORM)
	printf("  Denormalized numbers\n");
if(flag & CL_FP_ROUND_TO_NEAREST)
	printf("  Round To Nearest Even mode\n");
if(flag & CL_FP_ROUND_TO_INF)
	printf("  Round To Infinity mode\n");
if(flag & CL_FP_ROUND_TO_ZERO)
	printf("  Round To Zero mode\n");
if(flag & CL_FP_FMA)
	printf("  Floating-point multiply-and-add operation\n\n");
andrea_d_
How you managed to install Code Builder onto a 14.04? It is released just for 12.04.
Gu_S_
Yup, saw your other question here on that (but dont know the answer). That 'unsupported OS' warning during installation was optional, and so I went ahead and installed it anyways. It works fine so far.
andrea_d_
Ok, thanks :) Have you found the double precision extension? Keep us posted!
