OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1745 Discussions
Offline 64-bit Compiler crash
Jiri_Matejka
when I try to build the following code with 64-bit compiler, it crashes. 32-bit compiler hangs with this code.
OS: Win7 64-bit
CPU: Core i5
SDK Version: latest (1.1) (Please consider displaying a revision of the SDK in the download page to simplify referring to the exact version here in forums)
float f(float3 g)
return g.x();
The code apparently contains an error in getting vector component. When I correct it, compiler builds fine.
Jiri Matejka
Evgeny_F_Intel
Hi Jiri,
Thank you for reporting the issue and finding the workaround.
Evgeny
Jiri_Matejka
just one extra question, are you planning to fix this issue?
This error was caused when I ported C++ code (Qt) to OpenCL. And because the compiler crashes it was hard to identify where the problem can be.
Expected behaviour of the compiler is to report a syntax error instead of crash.
Thank you in advance,
Jiri
Evgeny_F_Intel
Once the issue will be reproduced on our side we will fix it.
However, i can't communicate when the fix will be released.
Evgeny
