OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1745 Discussions
OpenCL example program(HelloWorld.cpp) cmake&make failed! CentOS 7
然_魏_
I download example code in “OpenCL Programming Guide” (by Aaftab Munshi…), but some error occurred while cmake .
[  OpenCL_Programming_Guide]# pwd
/home/OpenCL_Study/OpenCL_Programming_Guide
[  OpenCL_Programming_Guide]# cmake .
CMake Error at /usr/local/share/cmake-3.4/Modules/FindPackageHandleStandardArgs.cmake:148 (message):
  Could NOT find OpenCL (missing: OPENCL_LIBRARIES OPENCL_INCLUDE_DIRS)
Call Stack (most recent call first):
  /usr/local/share/cmake-3.4/Modules/FindPackageHandleStandardArgs.cmake:388 (_FPHSA_FAILURE_MESSAGE)
  cmake/FindOpenCL.cmake:80 (FIND_PACKAGE_HANDLE_STANDARD_ARGS)
  CMakeLists.txt:9 (find_package)
-- Configuring incomplete, errors occurred!
See also "/home/OpenCL_Study/OpenCL_Programming_Guide/CMakeFiles/CMakeOutput.log".
[  OpenCL_Programming_Guide]# echo $OPENCL_LIBRARIES
/opt/intel/opencl-1.2-sdk-5.0.0.93/lib64
[  OpenCL_Programming_Guide]# echo $OPENCL_INCLUDE_DIRS
/opt/intel/opencl/include/
Both OPENCL_LIBRARIES and OPENCL_INCLUDE_DIRS were set manually by me. (Not set by installed intel_code_builder_for_opencl_2015_5.0.0.62_x64)
However, I used cmake-gui to cmake is OK:
[OPG_output]# make
Scanning dependencies of target HelloWorld
[  8%] Building CXX object src/Chapter_2/HelloWorld/CMakeFiles/HelloWorld.dir/HelloWorld.cpp.o
/home/OpenCL_Study/OpenCL_Programming_Guide/src/Chapter_2/HelloWorld/HelloWorld.cpp: In function \u2018_cl_command_queue* CreateCommandQueue(cl_context, _cl_device_id**)\u2019:
/home/OpenCL_Study/OpenCL_Programming_Guide/src/Chapter_2/HelloWorld/HelloWorld.cpp:116:20: warning: \u2018_cl_command_queue* clCreateCommandQueue(cl_context, cl_device_id, cl_command_queue_properties, cl_int*)\u2019 is deprecated (declared at /opt/intel/opencl/include/CL/cl.h:1359) [-Wdeprecated-declarations]
     commandQueue = clCreateCommandQueue(context, devices[0], 0, NULL);
/home/OpenCL_Study/OpenCL_Programming_Guide/src/Chapter_2/HelloWorld/HelloWorld.cpp:116:69: warning: \u2018_cl_command_queue* clCreateCommandQueue(cl_context, cl_device_id, cl_command_queue_properties, cl_int*)\u2019 is deprecated (declared at /opt/intel/opencl/include/CL/cl.h:1359) [-Wdeprecated-declarations]
Linking CXX executable HelloWorld
CMakeFiles/HelloWorld.dir/HelloWorld.cpp.o: In function `CreateContext()':
HelloWorld.cpp:(.text+0x21): undefined reference to `clGetPlatformIDs'
HelloWorld.cpp:(.text+0xa2): undefined reference to `clCreateContextFromType'
HelloWorld.cpp:(.text+0xeb): undefined reference to `clCreateContextFromType'
CMakeFiles/HelloWorld.dir/HelloWorld.cpp.o: In function `CreateCommandQueue(_cl_context*, _cl_device_id**)':
HelloWorld.cpp:(.text+0x161): undefined reference to `clGetContextInfo'
HelloWorld.cpp:(.text+0x1f4): undefined reference to `clGetContextInfo'
HelloWorld.cpp:(.text+0x243): undefined reference to `clCreateCommandQueue'
CMakeFiles/HelloWorld.dir/HelloWorld.cpp.o: In function `CreateProgram(_cl_context*, _cl_device_id*, char const*)':
HelloWorld.cpp:(.text+0x3ac): undefined reference to `clCreateProgramWithSource'
HelloWorld.cpp:(.text+0x404): undefined reference to `clBuildProgram'
HelloWorld.cpp:(.text+0x43a): undefined reference to `clGetProgramBuildInfo'
HelloWorld.cpp:(.text+0x476): undefined reference to `clReleaseProgram'
CMakeFiles/HelloWorld.dir/HelloWorld.cpp.o: In function `CreateMemObjects(_cl_context*, _cl_mem**, float*, float*)':
HelloWorld.cpp:(.text+0x535): undefined reference to `clCreateBuffer'
HelloWorld.cpp:(.text+0x564): undefined reference to `clCreateBuffer'
HelloWorld.cpp:(.text+0x590): undefined reference to `clCreateBuffer'
CMakeFiles/HelloWorld.dir/HelloWorld.cpp.o: In function `Cleanup(_cl_context*, _cl_command_queue*, _cl_program*, _cl_kernel*, _cl_mem**)':
HelloWorld.cpp:(.text+0x64e): undefined reference to `clReleaseMemObject'
HelloWorld.cpp:(.text+0x66b): undefined reference to `clReleaseCommandQueue'
HelloWorld.cpp:(.text+0x67e): undefined reference to `clReleaseKernel'
HelloWorld.cpp:(.text+0x691): undefined reference to `clReleaseProgram'
HelloWorld.cpp:(.text+0x6a4): undefined reference to `clReleaseContext'
CMakeFiles/HelloWorld.dir/HelloWorld.cpp.o: In function `main':
HelloWorld.cpp:(.text+0x7dd): undefined reference to `clCreateKernel'
HelloWorld.cpp:(.text+0x8d8): undefined reference to `clSetKernelArg'
HelloWorld.cpp:(.text+0x8fc): undefined reference to `clSetKernelArg'
HelloWorld.cpp:(.text+0x920): undefined reference to `clSetKernelArg'
HelloWorld.cpp:(.text+0x9bf): undefined reference to `clEnqueueNDRangeKernel'
HelloWorld.cpp:(.text+0xa52): undefined reference to `clEnqueueReadBuffer'
collect2: error: ld returned 1 exit status
make[2]: *** [src/Chapter_2/HelloWorld/HelloWorld] Error 1
make[1]: *** [src/Chapter_2/HelloWorld/CMakeFiles/HelloWorld.dir/all] Error 2
make: *** [all] Error 2
[  OPG_output]#
It’s seemed that I still not configure environment correctly. Could you give me some advices?
Something you may want to know:
# find / -name libOpenCL.so*
 /opt/intel/opencl/libOpenCL.so.1
 /opt/intel/opencl/libOpenCL.so.1.2
      8  Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
00:02.0 VGA compatible controller [0300]: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller [8086:0412] (rev 06)
Robert_I_Intel
When running cmake you can run it with -D options to specify the variables that you wish to define. Looks like you are not linking your executable correctly. Try to add /opt/intel/OpenCL/ to your LD_LIBRARY_PATH.
Could you also attach OpenCL_Programming_Guide.tar.gz to this thread so I can try to build it on my machine?
Thanks!
然_魏_
Thanks!
Please forgive me I’m a beginner in cmake…
I have tried lots of ways but still made the mistake…..
Whether:
[root@storm108 OpenCL_Programming_Guide]# cmake -D OPENCL_INCLUDE_DIRS=/opt/intel/opencl/include/
CMake Error: The source directory "/home/OpenCL_Study/OpenCL_Programming_Guide/OPENCL_INCLUDE_DIRS=/opt/intel/opencl/include" does not exist.
Or
# This is an example project to show and test the usage of the FindOpenCL
# script.
cmake_minimum_required( VERSION 2.6 )
project( CL_Book )
set(CMAKE_MODULE_PATH "${CMAKE_SOURCE_DIR}/cmake")
find_package( OpenCL REQUIRED )
include_directories( ${OPENCL_INCLUDE_DIRS} )
include_directories( /opt/intel/opencl/include/ ) #I added
include_directories( "${CMAKE_SOURCE_DIR}/khronos" )
link_directories( /opt/intel/opencl-1.2-sdk-5.0.0.93/lib64 ) #I added
SUBDIRS(src)
Etc…
All of them don’t work…
What should I do, could you give me some suggestions?
(code please see atteched~↓)
Robert_I_Intel
I was able to build with the following options
cmake -DOPENCL_INCLUDE_DIRS=/opt/intel/opencl/include -DOPENCL_LIBRARIES=/opt/intel/opencl/libOpenCL.so .
make
Note there are no spaces between -D and the variable it sets.
然_魏_
make
Great! it works! I really appreciate your help.
I think I should take cmake learning seriously...
