OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1737 Discussions
Problem:Unable to pass structure to a opencl kernel
明_王_
Unable to pass structure to a opencl kernel?
main.h
typedef struct _Point
  unsigned int x;
  unsigned int y;
}mPoint;
kernel.cl:
#include"main.h"
__kernel void Fun(__global struct mPoint* p)
    unsigned int tid = get_local_id(0);
    p->x=tid;
The error returned by clBuildProgram():
clBuild failed:-11
Compilation started
1:3:38: warning: declaration of 'struct mPoint' will not be visible outside of t
his function
1:6:3: error: incomplete definition of type 'struct mPoint'
1:3:38: note: forward declaration of 'struct mPoint'
Compilation failed
I don't known where is the mistake.
Alexey_B_Intel1
You should change __kernel void Fun(__global struct mPoint* p) definition.
The best way to fix your issue is to remove 'struct':
__kernel void Fun(__global mPoint* p)
明_王_
I removed 'struct', however, another question emerged:
error: must use 'struct' tag to refer to type 'mPoint'
                                      struct
Robert_I_Intel
Try to place the content of the main.h header file inside your kernel.cl file: I think what is going on is that when you compile your program, the compiler does not see your header file. Use -I option to the compiler (pass it to clBuildProgram) to point to the right directory where your header file will reside.
