OpenCL* for CPU
clGetPlatformIDs() returns -1001
ad1
I have installed the latest intel opencl sdk 2012
However the application stops at the point when it calls clGetPlatformIDs()
The function returns -1001
I can confirm that registry keys point correctly to IntelOpenCL32/64.dll, and the files exist in the system path
My CPU is i5-2500K
The same program runs fine on another pc with AMD opencl driver and i3 cpu
Please help and advise
Chuck_De_Sylva
Anton,
-1001 = CL_PLATFORM_NOT_FOUND_KHR, and is returned when clGetPlatformIDs() sees no platforms available. Obviously, you are trying to execute your code on the Intel HD graphics. Can you list the driver version you are using?
- Chuck
ad1
Chuck,
I want to run my code on CPU. I understand that it should be possible.
The idea is to have a CPU-fallback option when there is no compliant GPU, which is the case with sandy bridge.
More info: on the 2nd machine, with working amd opencl, I also installed intel opencl, and guess what? It still shows only amd platform.
I think I have the latest driver (maybe late 2012)
Chuck_De_Sylva
Anton,
That is interesting. This is on Windows? Which version? 32 or 64 bit? If you install the GPU Caps viewer, what platform does it show you?
- Chuck
ad1
Chuck,
Windows 7 x64.
Driver 8.15.10.2696, apparently 3/19/2012
Raghupathi_M_Intel
Anton,
What does GPU Caps viewer show under "OpenCL"?
Raghu
ad1
Chuck,
I updated my driver to 12'2012 and now it works fine
Thanks for the hint
Don't worry, I have already slapped myself for not having the latest driver :/
Chuck_De_Sylva
Anton,
No problem. Glad to here it is working for you.
- Chuck
ad1
Chuck,
BTW do I understand correctly that I need to have intel graphics driver istalled (and probably to have intel graphics enabled in bios and device manager) for intel opencl to run on CPU?
Raghupathi_M_Intel
No that's not true. You can just install the CPU runtime to expose the OpenCL CPU device. I am guessing there was some other problem with your previous installation and the runtime probably didnt detect your device.
