OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1745 Discussions
feedback on my OpenCL needs
madshi_net
Hi Intel,
happy to see you're doing OpenCL. Since you explicitly said you're looking for feedback, I'll describe my situation/needs, in the hope that it might be useful.
I'm working on a high quality video renderer for HTPCs (home theater PCs). For this purpose CPU powered OpenCL doesn't work. GPU support is required. One of the main reasons for this is that after DXVA decoding the video frames are stored in GPU RAM. Transfering them back to system RAM, processing them there and then transfering them once again to the GPU costs so much performance that it's all not useful, anymore. I've measured that with Intel GPUs transfering NV12 DXVA 1080p frames from GPU RAM to system RAM runs with less than 24fps. So already the simple GPU -> system RAM transfer is so slow that I can't use it at all for real time video playback.
My exact requirements are these:
- OpenCL kernels need to run on GPU
- Direct3D9 interop is necessary (DirectShow/MediaFoundation is based on DX9)
- need ability for OpenCL kernels to access NV12 DXVA decoding surfaces
Thank you.
P.S: A bit OT, but I'm desperate: Is there any way to sign an NDA to get access to confidential specs and SDKs? E.g. I've been trying hard for *months* to get access to the Intel CUI SDK. No chance in hell, it seems, which really is a pain. Generally Intel GPU related information (e.g. DXVA decoding, h264 MVC decoding, activating frame packed 3D output etc) is nearly impossible to get. If you can do anything to improve that, that would be wonderful.
Best regards, Mathias.
www.madshi.net
Systemsoftware Mathias Rauen
ARNON_P_Intel
Thank you for the feedback. It is important for us and very helpful.
For NDA access, best to join the Intel Software Partner Program at: http://www3.intel.com/cd/software/partner/asmo-na/eng/index.htm
Let us know if it works for you.
Arnon
madshi_net
Thanks. The Software Partner Program itself didn't help me much. However, through it I found the Intel "Developing Software for Visual Computing" forum, which seems to be a good place for my needs.
ARNON_P_Intel
Right,
If you are media developer, the Visual Adrenaline site and program are the your destination.
Thanks for the feedback.
Keep going,
Arnon
