OpenCL* for CPU
kernel with pipe parameter: compilation error
ZVere
I tried compiling the following kernel with the last version of OpenCL SDK:
__kernel void pipe_producer (__write_only pipe float rng_pipe)
And got the following errors:
1:3:30: error: expected parameter declarator
1:3:43: error: expected ')'
1:3:29: note: to match this '('
Compilation failed
Can you tell why ?
Z.V
Robert_I_Intel
Hi Zvi,
Pipes are an OpenCL 2.0 feature. Please add the following flag to your build options: -cl-std=CL2.0
Using build options: -cl-std=CL2.0
OpenCL Intel(R) Graphics device was found!
Device name: Intel(R) Iris(TM) Graphics 6100
Device version: OpenCL 2.0
Device vendor: Intel(R) Corporation
Device profile: FULL_PROFILE
fcl build 1 succeeded.
fcl build 2 succeeded.
bcl build succeeded.
pipe_producer info:
 Maximum work-group size: 256
 Compiler work-group size: (0, 0, 0)
 Local memory size: 0
 Preferred multiple of work-group size: 32
 Minimum amount of private memory: 0
Build succeeded!
Robert_I_Intel
Hi Zvi,
pipe_producer info:
Build succeeded!
ZVere
Hi Robert,
Thank you for your help.
Z.V
