OpenCL* for CPU
1733 Discussions
problem with read_imagef
amina_z_
hello,
I am new with OpenCL
Iam using it with jOCL in java platform
My problem is that I want to read an image pixels using read_imagef, and all the results of it returns 0.0 (.x .y .z .w) knowing that the image is contains red area.
here is my kernel
const sampler_t smp =     CLK_NORMALIZED_COORDS_FALSE | CLK_ADDRESS_CLAMP | CLK_FILTER_NEAREST;
__kernel void basic(__read_only image2d_t input,__global int  *result)
   int gidX = get_global_id(0);
    int gidY = get_global_id(1);
int2 coord = (int2)(get_global_id(0), get_global_id(1));
int2 posIn = {gidX, gidY};
      float4 pixel = read_imagef(input, smp, posIn);
result [gidX]= as_int(pixel.x);
what do you think the problem is???
Joose_S_
read_imagef() returns floats that are normalized between 0 and 1. So depening on what as_int() does you are probably just casint a float between 0 and 1 to in which will result in a zero.
amina_z_
No, I used also float variable and it always returns  0.0
Joose_S_
Can you show the buffer allocation on host code including the image format object? You should also try printing the values inside the kernel to see if they get to that point to begin with.
amina_z_
Here is my buffer allocation
DataBufferInt dataBufferSrc =
                    (DataBufferInt)image.getRaster().getDataBuffer();
                int dataSrc[] = dataBufferSrc.getData();
                cl_image_format imageFormat = new cl_image_format();
                imageFormat.image_channel_order = CL_RGBA;
                imageFormat.image_channel_data_type =CL_UNORM_INT8;
                		//CL_UNSIGNED_INT8;
                inputImageMem = clCreateImage2D(
                    context, CL_MEM_READ_ONLY | CL_MEM_USE_HOST_PTR,
                    new cl_image_format[]{imageFormat}, sizeX, sizeY,
                    sizeX * Sizeof.cl_uint, Pointer.to(dataSrc), null);
            cl_mem memObjects[] = new cl_mem[2];
            memObjects[0] = clCreateBuffer(context,
                    CL_MEM_READ_WRITE,   Sizeof.cl_uint * sizeX, null, null);
I changed CL_UNORM_INT8 to CL_UNSIGNED_INT8 but there was no difference, I will try to print the result in the kernel
amina_z_
I tried to print te result in the OpenC Code  builder but the pplication is blocked
When I build it is OK but when I want tosee the result by analysing it is deprecated
Could you know the reason???
Jeffrey_M_Intel1
Could you send more info on what you found was deprecated/blocked?  Which OpenCL release are you using?  On which operating system?
For an example using read_imagef, the Intel SDK for OpenCL applications Codebuilder Visual Studio integration can generate a starting point based on images.  It can often be helpful to begin with a known good starting point.
