Community
cancel
Showing results for
Search instead for
Did you mean:
Advisory for installer hangs for 2019 update 5 SDK on Windows* OS...
Multiple users have reported installation hangs for the 2019 Update 5 version of the SDK. This issue is under investigation.
Speculation is that some .NET configurations may be blocking the installer.
The recommendation that some users confirmed as a work around was to run the installer by hand for .NET 3.5 like so:
install.exe --net35
install.exe is available in the root of the installation .zip file available from the Intel Registration Center download portal for the product. Reference:
Portal - Windows
Reports and references from other users:
Please use this thread to send any screen shots or installation logs which may be available.
Installer logs are typically located in a folder structure that looks like this: %TEMP%\pset_tmp  or...
folders underneath %TEMP% with 'intel' in the folder name.
Thank you for your interest.
-MichaelC
