OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1719 Discussions
Are there *any* circumstances that will implicitly allocate shared local memory?
allanmac1
I'm curious if there are any circumstances that will result in an implicit increase in a kernel workgroup's shared memory requirements?
For example, do the workgroup (or subgroup) functions like scan or reduce quietly "reserve" SLM?
If there are any circumstances where this might happen on SB, IVB, HSW or BDW then could you list them?
Robert_I_Intel
Allan,
The following functions do implicitly reserve SLM on BDW, since all of them are OpenCL 2.0 functions:
work_group_broadcast()
work_group_any()
work_group_all()
work_group_reduce<op>()
work_group_scan_inclusive<op>()
work_group_scan_exclusive<op>()
The amount of reserved local memory varies per function, for example broadcast / any / all require less local memory than reduce / scan.
We currently use implicit SLM in the implementation, but things could always change in the future.
allanmac1
Perfect, that makes sense.
I'll assume clGetKernelWorkGroupInfo(CL_KERNEL_LOCAL_MEM_SIZE) will properly report the extra SLM in use.
Thanks for the clarification.
