Community
cancel
Showing results for
Search instead for
Did you mean:
Bug in OpenCL kernel builder on Intel HD Graphics
Jump to solution
Hello.
I found a curious bug in kernel builder of Intel OpenCL SDK (Version 2013 R3 64-bit) when it executes on Intel HD Graphics 4600 (Core i5 4570).
I write following kernel:
#define cn 1
__local uchar val1; val1 = 19;
__local uchar val2; val2 = 18;
__local uchar val3; val3 = 9;
__local uchar res; res = 255;
for (int c = 0; c < cn; ++c)
    if ( val2 > val1 || val3 < val1 )
            res = 0;
            break;
This is a simplified version of a piece of code of InRange function from OpenCV library.
Correct value 'res' variable is 0, but I have 255. On other platforms (Intel CPU, NVIDIA, AMD) this code works correct. If remove 'break' this code works fine on all platforms.
HD Graphics driver version: 9.18.10.3257
Accepted Solutions
I verified that indeed the 3257 driver has the bug. Please update the driver and let us know.
Raghu
Hi Alexander,
The driver you are using is old. It is possible that there is a bug in that version, but I tested this on the latest driver on downloadcenter.intel.com (10.18.10.3345) and I get the correct result. Is it possible for you to update the driver and try again?
Raghu
Raghu
Hi Raghu,
I installed new version of HD graphics driver and this code works correctly.
Thanks a lot!
