Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Building opencl kernels clCreateProgramWithSource/clBuildProgram
I'm trying to build the following kernel:
#pragma OPENCL EXTENSION cl_amd_media_ops2 : enable
#include "wolf-aes.cl"
#include "wolf-skein.cl"
#include "jh.cl"
#include "blake256.cl"
#include "groestl256.cl"
static const __constant ulong keccakf_rndc[24] =
    0x0000000000000001, 0x0000000000008082, 0x800000000000808a,
    0x8000000080008000, 0x000000000000808b, 0x0000000080000001,
    0x8000000080008081, 0x8000000000008009, 0x000000000000008a,
    0x0000000000000088, 0x0000000080008009, 0x000000008000000a,
    0x000000008000808b, 0x800000000000008b, 0x8000000000008089,
    0x8000000000008003, 0x8000000000008002, 0x8000000000000080,
    0x000000000000800a, 0x800000008000000a, 0x8000000080008081,
    0x8000000000008080, 0x0000000080000001, 0x8000000080008008
static const __constant uchar sbox[256] =
    0x63, 0x7C, 0x77, 0x7B, 0xF2, 0x6B, 0x6F, 0xC5, 0x30, 0x01, 0x67, 0x2B, 0xFE, 0xD7, 0xAB, 0x76,
    0xCA, 0x82, 0xC9, 0x7D, 0xFA, 0x59, 0x47, 0xF0, 0xAD, 0xD4, 0xA2, 0xAF, 0x9C, 0xA4, 0x72, 0xC0,
    0xB7, 0xFD, 0x93, 0x26, 0x36, 0x3F, 0xF7, 0xCC, 0x34, 0xA5, 0xE5, 0xF1, 0x71, 0xD8, 0x31, 0x15,
    0x04, 0xC7, 0x23, 0xC3, 0x18, 0x96, 0x05, 0x9A, 0x07, 0x12, 0x80, 0xE2, 0xEB, 0x27, 0xB2, 0x75,
    0x09, 0x83, 0x2C, 0x1A, 0x1B, 0x6E, 0x5A, 0xA0, 0x52, 0x3B, 0xD6, 0xB3, 0x29, 0xE3, 0x2F, 0x84,
    0x53, 0xD1, 0x00, 0xED, 0x20, 0xFC, 0xB1, 0x5B, 0x6A, 0xCB, 0xBE, 0x39, 0x4A, 0x4C, 0x58, 0xCF,
    0xD0, 0xEF, 0xAA, 0xFB, 0x43, 0x4D, 0x33, 0x85, 0x45, 0xF9, 0x02, 0x7F, 0x50, 0x3C, 0x9F, 0xA8,
    0x51, 0xA3, 0x40, 0x8F, 0x92, 0x9D, 0x38, 0xF5, 0xBC, 0xB6, 0xDA, 0x21, 0x10, 0xFF, 0xF3, 0xD2,
    0xCD, 0x0C, 0x13, 0xEC, 0x5F, 0x97, 0x44, 0x17, 0xC4, 0xA7, 0x7E, 0x3D, 0x64, 0x5D, 0x19, 0x73,
    0x60, 0x81, 0x4F, 0xDC, 0x22, 0x2A, 0x90, 0x88, 0x46, 0xEE, 0xB8, 0x14, 0xDE, 0x5E, 0x0B, 0xDB,
    0xE0, 0x32, 0x3A, 0x0A, 0x49, 0x06, 0x24, 0x5C, 0xC2, 0xD3, 0xAC, 0x62, 0x91, 0x95, 0xE4, 0x79,
    0xE7, 0xC8, 0x37, 0x6D, 0x8D, 0xD5, 0x4E, 0xA9, 0x6C, 0x56, 0xF4, 0xEA, 0x65, 0x7A, 0xAE, 0x08,
    0xBA, 0x78, 0x25, 0x2E, 0x1C, 0xA6, 0xB4, 0xC6, 0xE8, 0xDD, 0x74, 0x1F, 0x4B, 0xBD, 0x8B, 0x8A,
    0x70, 0x3E, 0xB5, 0x66, 0x48, 0x03, 0xF6, 0x0E, 0x61, 0x35, 0x57, 0xB9, 0x86, 0xC1, 0x1D, 0x9E,
    0xE1, 0xF8, 0x98, 0x11, 0x69, 0xD9, 0x8E, 0x94, 0x9B, 0x1E, 0x87, 0xE9, 0xCE, 0x55, 0x28, 0xDF,
    0x8C, 0xA1, 0x89, 0x0D, 0xBF, 0xE6, 0x42, 0x68, 0x41, 0x99, 0x2D, 0x0F, 0xB0, 0x54, 0xBB, 0x16
void keccakf1600(ulong *s)
    for(int i = 0; i < 24; ++i)
        ulong bc[5], tmp1, tmp2;
        bc[0] = s[0] ^ s[5] ^ s[10] ^ s[15] ^ s[20] ^ rotate(s[2] ^ s[7] ^ s[12] ^ s[17] ^ s[22], 1UL);
        bc[1] = s[1] ^ s[6] ^ s[11] ^ s[16] ^ s[21] ^ rotate(s[3] ^ s[8] ^ s[13] ^ s[18] ^ s[23], 1UL);
        bc[2] = s[2] ^ s[7] ^ s[12] ^ s[17] ^ s[22] ^ rotate(s[4] ^ s[9] ^ s[14] ^ s[19] ^ s[24], 1UL);
        bc[3] = s[3] ^ s[8] ^ s[13] ^ s[18] ^ s[23] ^ rotate(s[0] ^ s[5] ^ s[10] ^ s[15] ^ s[20], 1UL);
        bc[4] = s[4] ^ s[9] ^ s[14] ^ s[19] ^ s[24] ^ rotate(s[1] ^ s[6] ^ s[11] ^ s[16] ^ s[21], 1UL);
        tmp1 = s[1] ^ bc[0];
        s[0] ^= bc[4];
        s[1] = rotate(s[6] ^ bc[0], 44UL);
        s[6] = rotate(s[9] ^ bc[3], 20UL);
        s[9] = rotate(s[22] ^ bc[1], 61UL);
        s[22] = rotate(s[14] ^ bc[3], 39UL);
        s[14] = rotate(s[20] ^ bc[4], 18UL);
        s[20] = rotate(s[2] ^ bc[1], 62UL);
        s[2] = rotate(s[12] ^ bc[1], 43UL);
        s[12] = rotate(s[13] ^ bc[2], 25UL);
        s[13] = rotate(s[19] ^ bc[3], 8UL);
        s[19] = rotate(s[23] ^ bc[2], 56UL);
        s[23] = rotate(s[15] ^ bc[4], 41UL);
        s[15] = rotate(s[4] ^ bc[3], 27UL);
        s[4] = rotate(s[24] ^ bc[3], 14UL);
        s[24] = rotate(s[21] ^ bc[0], 2UL);
        s[21] = rotate(s[8] ^ bc[2], 55UL);
        s[8] = rotate(s[16] ^ bc[0], 35UL);
        s[16] = rotate(s[5] ^ bc[4], 36UL);
        s[5] = rotate(s[3] ^ bc[2], 28UL);
        s[3] = rotate(s[18] ^ bc[2], 21UL);
        s[18] = rotate(s[17] ^ bc[1], 15UL);
        s[17] = rotate(s[11] ^ bc[0], 10UL);
        s[11] = rotate(s[7] ^ bc[1], 6UL);
        s[7] = rotate(s[10] ^ bc[4], 3UL);
        s[10] = rotate(tmp1, 1UL);
        tmp1 = s[0]; tmp2 = s[1]; s[0] = bitselect(s[0] ^ s[2], s[0], s[1]); s[1] = bitselect(s[1] ^ s[3], s[1], s[2]); s[2] = bitselect(s[2] ^ s[4], s[2], s[3]); s[3] = bitselect(s[3] ^ tmp1, s[3], s[4]); s[4] = bitselect(s[4] ^ tmp2, s[4], tmp1);
        tmp1 = s[5]; tmp2 = s[6]; s[5] = bitselect(s[5] ^ s[7], s[5], s[6]); s[6] = bitselect(s[6] ^ s[8], s[6], s[7]); s[7] = bitselect(s[7] ^ s[9], s[7], s[8]); s[8] = bitselect(s[8] ^ tmp1, s[8], s[9]); s[9] = bitselect(s[9] ^ tmp2, s[9], tmp1);
        tmp1 = s[10]; tmp2 = s[11]; s[10] = bitselect(s[10] ^ s[12], s[10], s[11]); s[11] = bitselect(s[11] ^ s[13], s[11], s[12]); s[12] = bitselect(s[12] ^ s[14], s[12], s[13]); s[13] = bitselect(s[13] ^ tmp1, s[13], s[14]); s[14] = bitselect(s[14] ^ tmp2, s[14], tmp1);
        tmp1 = s[15]; tmp2 = s[16]; s[15] = bitselect(s[15] ^ s[17], s[15], s[16]); s[16] = bitselect(s[16] ^ s[18], s[16], s[17]); s[17] = bitselect(s[17] ^ s[19], s[17], s[18]); s[18] = bitselect(s[18] ^ tmp1, s[18], s[19]); s[19] = bitselect(s[19] ^ tmp2, s[19], tmp1);
        tmp1 = s[20]; tmp2 = s[21]; s[20] = bitselect(s[20] ^ s[22], s[20], s[21]); s[21] = bitselect(s[21] ^ s[23], s[21], s[22]); s[22] = bitselect(s[22] ^ s[24], s[22], s[23]); s[23] = bitselect(s[23] ^ tmp1, s[23], s[24]); s[24] = bitselect(s[24] ^ tmp2, s[24], tmp1);
        s[0] ^= keccakf_rndc;
static const __constant uint keccakf_rotc[24] =
    1,  3,  6,  10, 15, 21, 28, 36, 45, 55, 2,  14,
    27, 41, 56, 8,  25, 43, 62, 18, 39, 61, 20, 44
static const __constant uint keccakf_piln[24] =
    10, 7,  11, 17, 18, 3, 5,  16, 8,  21, 24, 4,
    15, 23, 19, 13, 12, 2, 20, 14, 22, 9,  6,  1
void keccakf1600_1(ulong *st)
    int i, round;
    ulong t, bc[5];
    #pragma unroll 1
    for(round = 0; round < 24; ++round)
        // Theta
        bc[0] = st[0] ^ st[5] ^ st[10] ^ st[15] ^ st[20];
        bc[1] = st[1] ^ st[6] ^ st[11] ^ st[16] ^ st[21];
        bc[2] = st[2] ^ st[7] ^ st[12] ^ st[17] ^ st[22];
        bc[3] = st[3] ^ st[8] ^ st[13] ^ st[18] ^ st[23];
        bc[4] = st[4] ^ st[9] ^ st[14] ^ st[19] ^ st[24];
        #pragma unroll 1
        for (i = 0; i < 5; ++i) {
            t = bc[(i + 4) % 5] ^ rotate(bc[(i + 1) % 5], 1UL);
            st[i     ] ^= t;
            st[i +  5] ^= t;
            st[i + 10] ^= t;
            st[i + 15] ^= t;
            st[i + 20] ^= t;
        // Rho Pi
        t = st[1];
        #pragma unroll
        for (i = 0; i < 24; ++i) {
            bc[0] = st[keccakf_piln];
            st[keccakf_piln] = rotate(t, (ulong)keccakf_rotc);
            t = bc[0];
        //ulong tmp1 = st[0]; ulong tmp2 = st[1]; st[0] = bitselect(st[0] ^ st[2], st[0], st[1]); st[1] = bitselect(st[1] ^ st[3], st[1], st[2]); st[2] = bitselect(st[2] ^ st[4], st[2], st[3]); st[3] = bitselect(st[3] ^ tmp1, st[3], st[4]); st[4] = bitselect(st[4] ^ tmp2, st[4], tmp1);
        //tmp1 = st[5]; tmp2 = st[6]; st[5] = bitselect(st[5] ^ st[7], st[5], st[6]); st[6] = bitselect(st[6] ^ st[8], st[6], st[7]); st[7] = bitselect(st[7] ^ st[9], st[7], st[8]); st[8] = bitselect(st[8] ^ tmp1, st[8], st[9]); st[9] = bitselect(st[9] ^ tmp2, st[9], tmp1);
        //tmp1 = st[10]; tmp2 = st[11]; st[10] = bitselect(st[10] ^ st[12], st[10], st[11]); st[11] = bitselect(st[11] ^ st[13], st[11], st[12]); st[12] = bitselect(st[12] ^ st[14], st[12], st[13]); st[13] = bitselect(st[13] ^ tmp1, st[13], st[14]); st[14] = bitselect(st[14] ^ tmp2, st[14], tmp1);
        //tmp1 = st[15]; tmp2 = st[16]; st[15] = bitselect(st[15] ^ st[17], st[15], st[16]); st[16] = bitselect(st[16] ^ st[18], st[16], st[17]); st[17] = bitselect(st[17] ^ st[19], st[17], st[18]); st[18] = bitselect(st[18] ^ tmp1, st[18], st[19]); st[19] = bitselect(st[19] ^ tmp2, st[19], tmp1);
        //tmp1 = st[20]; tmp2 = st[21]; st[20] = bitselect(st[20] ^ st[22], st[20], st[21]); st[21] = bitselect(st[21] ^ st[23], st[21], st[22]); st[22] = bitselect(st[22] ^ st[24], st[22], st[23]); st[23] = bitselect(st[23] ^ tmp1, st[23], st[24]); st[24] = bitselect(st[24] ^ tmp2, st[24], tmp1);
        #pragma unroll 1
        for(int i = 0; i < 25; i += 5)
            ulong tmp[5];
            #pragma unroll 1
            for(int x = 0; x < 5; ++x)
                tmp = bitselect(st[i + x] ^ st[i + ((x + 2) % 5)], st[i + x], st[i + ((x + 1) % 5)]);
            #pragma unroll 1
            for(int x = 0; x < 5; ++x) st[i + x] = tmp;
        //  Iota
        st[0] ^= keccakf_rndc[round];
void keccakf1600_2(ulong *st)
    int i, round;
    ulong t, bc[5];
    #pragma unroll 1
        // Theta
        //bc[0] = st[0] ^ st[5] ^ st[10] ^ st[15] ^ st[20];
        //bc[1] = st[1] ^ st[6] ^ st[11] ^ st[16] ^ st[21];
        //bc[2] = st[2] ^ st[7] ^ st[12] ^ st[17] ^ st[22];
        //bc[3] = st[3] ^ st[8] ^ st[13] ^ st[18] ^ st[23];
        //bc[4] = st[4] ^ st[9] ^ st[14] ^ st[19] ^ st[24];
        #pragma unroll
            st[i     ] ^= t;
            st[i +  5] ^= t;
            st[i + 10] ^= t;
            st[i + 15] ^= t;
            st[i + 20] ^= t;
        bc[0] = st[0] ^ st[5] ^ st[10] ^ st[15] ^ st[20] ^ rotate(st[2] ^ st[7] ^ st[12] ^ st[17] ^ st[22], 1UL);
        bc[1] = st[1] ^ st[6] ^ st[11] ^ st[16] ^ st[21] ^ rotate(st[3] ^ st[8] ^ st[13] ^ st[18] ^ st[23], 1UL);
        bc[2] = st[2] ^ st[7] ^ st[12] ^ st[17] ^ st[22] ^ rotate(st[4] ^ st[9] ^ st[14] ^ st[19] ^ st[24], 1UL);
        bc[3] = st[3] ^ st[8] ^ st[13] ^ st[18] ^ st[23] ^ rotate(st[0] ^ st[5] ^ st[10] ^ st[15] ^ st[20], 1UL);
        bc[4] = st[4] ^ st[9] ^ st[14] ^ st[19] ^ st[24] ^ rotate(st[1] ^ st[6] ^ st[11] ^ st[16] ^ st[21], 1UL);
        st[0] ^= bc[4];
        st[5] ^= bc[4];
        st[10] ^= bc[4];
        st[15] ^= bc[4];
        st[20] ^= bc[4];
        st[1] ^= bc[0];
        st[6] ^= bc[0];
        st[11] ^= bc[0];
        st[16] ^= bc[0];
        st[21] ^= bc[0];
        st[2] ^= bc[1];
        st[7] ^= bc[1];
        st[12] ^= bc[1];
        st[17] ^= bc[1];
        st[22] ^= bc[1];
        st[3] ^= bc[2];
        st[8] ^= bc[2];
        st[13] ^= bc[2];
        st[18] ^= bc[2];
        st[23] ^= bc[2];
        st[4] ^= bc[3];
        st[9] ^= bc[3];
        st[14] ^= bc[3];
        st[19] ^= bc[3];
        st[24] ^= bc[3];
        // Rho Pi
        t = st[1];
        #pragma unroll
            t = bc[0];
        /*ulong tmp1 = st[1] ^ bc[0];
        st[0] ^= bc[4];
        st[1] = rotate(st[6] ^ bc[0], 44UL);
        st[6] = rotate(st[9] ^ bc[3], 20UL);
        st[9] = rotate(st[22] ^ bc[1], 61UL);
        st[22] = rotate(st[14] ^ bc[3], 39UL);
        st[14] = rotate(st[20] ^ bc[4], 18UL);
        st[20] = rotate(st[2] ^ bc[1], 62UL);
        st[2] = rotate(st[12] ^ bc[1], 43UL);
        st[12] = rotate(st[13] ^ bc[2], 25UL);
        st[13] = rotate(st[19] ^ bc[3], 8UL);
        st[19] = rotate(st[23] ^ bc[2], 56UL);
        st[23] = rotate(st[15] ^ bc[4], 41UL);
        st[15] = rotate(st[4] ^ bc[3], 27UL);
        st[4] = rotate(st[24] ^ bc[3], 14UL);
        st[24] = rotate(st[21] ^ bc[0], 2UL);
        st[21] = rotate(st[8] ^ bc[2], 55UL);
        st[8] = rotate(st[16] ^ bc[0], 35UL);
        st[16] = rotate(st[5] ^ bc[4], 36UL);
        st[5] = rotate(st[3] ^ bc[2], 28UL);
        st[3] = rotate(st[18] ^ bc[2], 21UL);
        st[18] = rotate(st[17] ^ bc[1], 15UL);
        st[17] = rotate(st[11] ^ bc[0], 10UL);
        st[11] = rotate(st[7] ^ bc[1], 6UL);
        st[7] = rotate(st[10] ^ bc[4], 3UL);
        st[10] = rotate(tmp1, 1UL);
        #pragma unroll
            ulong tmp1 = st, tmp2 = st[i + 1];
            st = bitselect(st ^ st[i + 2], st, st[i + 1]);
            st[i + 1] = bitselect(st[i + 1] ^ st[i + 3], st[i + 1], st[i + 2]);
            st[i + 2] = bitselect(st[i + 2] ^ st[i + 4], st[i + 2], st[i + 3]);
            st[i + 3] = bitselect(st[i + 3] ^ tmp1, st[i + 3], st[i + 4]);
            st[i + 4] = bitselect(st[i + 4] ^ tmp2, st[i + 4], tmp1);
        //  Iota
void CNKeccak(ulong *output, ulong *input)
    ulong st[25];
    // Copy 72 bytes
    for(int i = 0; i < 9; ++i) st = input;
    // Last four and '1' bit for padding
    //st[9] = as_ulong((uint2)(((uint *)input)[18], 0x00000001U));
    st[9] = (input[9] & 0x00000000FFFFFFFFUL) | 0x0000000100000000UL;
    for(int i = 10; i < 25; ++i) st = 0x00UL;
    // Last bit of padding
    st[16] = 0x8000000000000000UL;
    keccakf1600_1(st);
    for(int i = 0; i < 25; ++i) output = st;
static const __constant uchar rcon[8] = { 0x8d, 0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40 };
#define BYTE(x, y)    (amd_bfe((x), (y) << 3U, 8U))
#define SubWord(inw)        ((sbox[BYTE(inw, 3)] << 24) | (sbox[BYTE(inw, 2)] << 16) | (sbox[BYTE(inw, 1)] << 8) | sbox[BYTE(inw, 0)])
void AESExpandKey256(uint *keybuf)
    //#pragma unroll 4
    for(uint c = 8, i = 1; c < 60; ++c)
        // For 256-bit keys, an sbox permutation is done every other 4th uint generated, AND every 8th
        uint t = ((!(c & 7)) || ((c & 7) == 4)) ? SubWord(keybuf[c - 1]) : keybuf[c - 1];
        // If the uint we're generating has an index that is a multiple of 8, rotate and XOR with the round constant,
        // then XOR this with previously generated uint. If it's 4 after a multiple of 8, only the sbox permutation
        // is done, followed by the XOR. If neither are true, only the XOR with the previously generated uint is done.
        keybuf = keybuf[c - 8] ^ ((!(c & 7)) ? rotate(t, 24U) ^ as_uint((uchar4)(rcon[i++], 0U, 0U, 0U)) : t);
#define IDX(x)    ((x) * (get_global_size(0)))
__attribute__((reqd_work_group_size(WORKSIZE, 8, 1)))
__kernel void cn0(__global ulong *input, __global uint4 *Scratchpad, __global ulong *states)
    ulong State[25];
    uint ExpandedKey1[256];
    __local uint AES0[256], AES1[256], AES2[256], AES3[256];
    ulong inbuf[10];
    uint4 text;
    states += (25 * (get_global_id(0) - get_global_offset(0)));
    Scratchpad += ((get_global_id(0) - get_global_offset(0)));
    for(int i = get_local_id(0); i < 256; i += WORKSIZE)
        const uint tmp = AES0_C;
        AES0 = tmp;
        AES1 = rotate(tmp, 8U);
        AES2 = rotate(tmp, 16U);
        AES3 = rotate(tmp, 24U);
    ((ulong8 *)inbuf)[0] = vload8(0, input);
    inbuf[8] = input[8];
    inbuf[9] = (ulong)((__global uint *)input)[18];
    ((uint *)(((uchar *)inbuf) + 39))[0] = get_global_id(0);
    CNKeccak(State, inbuf);
    #pragma unroll
    for(int i = 0; i < 25; ++i) states = State;
    text = vload4(get_local_id(1) + 4, (uint *)(State));
    #pragma unroll
    for(int i = 0; i < 4; ++i) ((ulong *)ExpandedKey1) = State;
    AESExpandKey256(ExpandedKey1);
    mem_fence(CLK_LOCAL_MEM_FENCE);
    #pragma unroll 2
    for(int i = 0; i < 0x4000; ++i)
        #pragma unroll
        for(int j = 0; j < 10; ++j)
            text = AES_Round(AES0, AES1, AES2, AES3, text, ((uint4 *)ExpandedKey1));
        Scratchpad[IDX((i << 3) + get_local_id(1))] = text;
    mem_fence(CLK_GLOBAL_MEM_FENCE);
__attribute__((reqd_work_group_size(WORKSIZE, 1, 1)))
__kernel void cn1(__global uint4 *Scratchpad, __global ulong *states)
    ulong a[2], b[2];
        AES0 = tmp;
    a[0] = states[0] ^ states[4];
    b[0] = states[2] ^ states[6];
    a[1] = states[1] ^ states[5];
    b[1] = states[3] ^ states[7];
    uint4 b_x = ((uint4 *)b)[0];
    #pragma unroll 8
    for(int i = 0; i < 0x80000; ++i)
        ulong c[2];
        ((uint4 *)c)[0] = Scratchpad[IDX((a[0] & 0x1FFFF0) >> 4)];
        ((uint4 *)c)[0] = AES_Round(AES0, AES1, AES2, AES3, ((uint4 *)c)[0], ((uint4 *)a)[0]);
        //b_x ^= ((uint4 *)c)[0];
        Scratchpad[IDX((a[0] & 0x1FFFF0) >> 4)] = b_x ^ ((uint4 *)c)[0];
        uint4 tmp;
        tmp = Scratchpad[IDX((c[0] & 0x1FFFF0) >> 4)];
        a[1] += c[0] * as_ulong2(tmp).s0;
        a[0] += mul_hi(c[0], as_ulong2(tmp).s0);
        Scratchpad[IDX((c[0] & 0x1FFFF0) >> 4)] = ((uint4 *)a)[0];
        ((uint4 *)a)[0] ^= tmp;
        b_x = ((uint4 *)c)[0];
__kernel void cn2(__global uint4 *Scratchpad, __global ulong *states, __global uint *Branch0, __global uint *Branch1, __global uint *Branch2, __global uint *Branch3)
    uint ExpandedKey2[256];
    ulong State[25];
    uint4 text;
        AES0 = tmp;
    #if defined(__Tahiti__) || defined(__Pitcairn__)
    for(int i = 0; i < 4; ++i) ((ulong *)ExpandedKey2) = states[i + 4];
    text = vload4(get_local_id(1) + 4, (__global uint *)states);
    #else
    ((uint8 *)ExpandedKey2)[0] = vload8(1, (__global uint *)states);
    #endif
    AESExpandKey256(ExpandedKey2);
    barrier(CLK_LOCAL_MEM_FENCE);
    #pragma unroll 2
        text ^= Scratchpad[IDX((i << 3) + get_local_id(1))];
        #pragma unroll
            text = AES_Round(AES0, AES1, AES2, AES3, text, ((uint4 *)ExpandedKey2));
    vstore2(as_ulong2(text), get_local_id(1) + 4, states);
    barrier(CLK_GLOBAL_MEM_FENCE);
    if(!get_local_id(1))
        for(int i = 0; i < 25; ++i) State = states;
        keccakf1600_2(State);
        switch(State[0] & 3)
            case 0:
                Branch0[atomic_inc(Branch0 + get_global_size(0))] = get_global_id(0) - get_global_offset(0);
                break;
            case 1:
                Branch1[atomic_inc(Branch1 + get_global_size(0))] = get_global_id(0) - get_global_offset(0);
                break;
            case 2:
                Branch2[atomic_inc(Branch2 + get_global_size(0))] = get_global_id(0) - get_global_offset(0);
                break;
            case 3:
                Branch3[atomic_inc(Branch3 + get_global_size(0))] = get_global_id(0) - get_global_offset(0);
                break;
__kernel void cryptonight(__global ulong *input, __global uint4 *Scratchpad, __global ulong *states, __global uint *Branch0, __global uint *Branch1, __global uint *Branch2, __global uint *Branch3, ulong ThreadCount)
    uchar State[200];
    uchar ExpandedKey1[256], ExpandedKey2[256];
    ulong inbuf[10], a[2], b[2];
    uint4 text[8];
    for(int i = 0; i < 256; ++i)
        AES0 = tmp;
    CNKeccak((ulong *)State, inbuf);
    a[0] = ((ulong *)State)[0] ^ ((ulong *)State)[4];
    b[0] = ((ulong *)State)[2] ^ ((ulong *)State)[6];
    a[1] = ((ulong *)State)[1] ^ ((ulong *)State)[5];
    b[1] = ((ulong *)State)[3] ^ ((ulong *)State)[7];
    for(uint i = 0; i < 8; ++i) text = vload4(i + 4, (uint *)(State));
    for(int i = 0; i < 4; ++i) ((ulong *)ExpandedKey1) = ((ulong *)State);
    for(int i = 0; i < 4; ++i) ((ulong *)ExpandedKey2) = ((ulong *)State)[i + 4];
    Scratchpad += ((1 << 17) * (get_global_id(0) - get_global_offset(0)));
    //#pragma unroll 1
    for(int i = 0; i < (1 << 17); i += 8)
        #pragma unroll
            #pragma unroll
            for(int x = 0; x < 8; ++x)
        for(int j = 0; j < 8; ++j) *(Scratchpad + i + j) = text;
    //#pragma unroll 1
        ulong c[2];
        ((uint4 *)c)[0] = Scratchpad[(a[0] & 0x1FFFF0) >> 4];
        Scratchpad[(a[0] & 0x1FFFF0) >> 4] = b_x;
        uint4 tmp;
        tmp = Scratchpad[(c[0] & 0x1FFFF0) >> 4];
        Scratchpad[(c[0] & 0x1FFFF0) >> 4] = ((uint4 *)a)[0];
        #pragma unroll
        for(int j = 0; j < 8; ++j) text ^= Scratchpad[i + j];
        #pragma unroll 1
            #pragma unroll
    for(uint i = 0; i < 8; ++i) vstore4(text, i + 4, (uint *)(State));
    keccakf1600((ulong *)State);
    for(int i = 0; i < 25; ++i) states = ((ulong *)State);
        case 0:
            Branch0[atomic_inc(Branch0 + ThreadCount)] = get_global_id(0) - get_global_offset(0);
            break;
        case 1:
            Branch1[atomic_inc(Branch1 + ThreadCount)] = get_global_id(0) - get_global_offset(0);
            break;
        case 2:
            Branch2[atomic_inc(Branch2 + ThreadCount)] = get_global_id(0) - get_global_offset(0);
            break;
        case 3:
            Branch3[atomic_inc(Branch3 + ThreadCount)] = get_global_id(0) - get_global_offset(0);
            break;
#define VSWAP8(x)    (((x) >> 56) | (((x) >> 40) & 0x000000000000FF00UL) | (((x) >> 24) & 0x0000000000FF0000UL) \
          | (((x) >>  8) & 0x00000000FF000000UL) | (((x) <<  8) & 0x000000FF00000000UL) \
          | (((x) << 24) & 0x0000FF0000000000UL) | (((x) << 40) & 0x00FF000000000000UL) | (((x) << 56) & 0xFF00000000000000UL))
#define VSWAP4(x)    ((((x) >> 24) & 0xFFU) | (((x) >> 8) & 0xFF00U) | (((x) << 8) & 0xFF0000U) | (((x) << 24) & 0xFF000000U))
__kernel void Skein(__global ulong *states, __global uint *BranchBuf, __global uint *output, uint Target)
    const ulong idx = get_global_id(0) - get_global_offset(0);
    states += 25 * BranchBuf[idx];
    // skein
    ulong8 h = vload8(0, SKEIN512_256_IV);
    // Type field begins with final bit, first bit, then six bits of type; the last 96
    // bits are input processed (including in the block to be processed with that tweak)
    // The output transform is only one run of UBI, since we need only 256 bits of output
    // The tweak for the output transform is Type = Output with the Final bit set
    // T[0] for the output is 8, and I don't know why - should be message size...
    ulong t[3] = { 0x00UL, 0x7000000000000000UL, 0x00UL };
    ulong8 p, m;
    for(uint i = 0; i < 4; ++i)
        if(i < 3) t[0] += 0x40UL;
        else t[0] += 0x08UL;
        t[2] = t[0] ^ t[1];
        m = (i < 3) ? vload8(i, states) : (ulong8)(states[24], 0UL, 0UL, 0UL, 0UL, 0UL, 0UL, 0UL);
        const ulong h8 = h.s0 ^ h.s1 ^ h.s2 ^ h.s3 ^ h.s4 ^ h.s5 ^ h.s6 ^ h.s7 ^ SKEIN_KS_PARITY;
        p = Skein512Block(m, h, h8, t);
        h = m ^ p;
        if(i < 2) t[1] = 0x3000000000000000UL;
        else t[1] = 0xB000000000000000UL;
    t[0] = 0x08UL;
    t[1] = 0xFF00000000000000UL;
    t[2] = t[0] ^ t[1];
    p = (ulong8)(0);
    p = Skein512Block(p, h, h8, t);
    //vstore8(p, 0, output);
    if(as_uint16(p).s7 <= Target) output[atomic_inc(output + 0xFF)] = BranchBuf[idx] + get_global_offset(0);
#define SWAP8(x)    as_ulong(as_uchar8(x).s76543210)
__kernel void JH(__global ulong *states, __global uint *BranchBuf, __global uint *output, uint Target)
    const uint idx = get_global_id(0) - get_global_offset(0);
    sph_u64 h0h = 0xEBD3202C41A398EBUL, h0l = 0xC145B29C7BBECD92UL, h1h = 0xFAC7D4609151931CUL, h1l = 0x038A507ED6820026UL, h2h = 0x45B92677269E23A4UL, h2l = 0x77941AD4481AFBE0UL, h3h = 0x7A176B0226ABB5CDUL, h3l = 0xA82FFF0F4224F056UL;
    sph_u64 h4h = 0x754D2E7F8996A371UL, h4l = 0x62E27DF70849141DUL, h5h = 0x948F2476F7957627UL, h5l = 0x6C29804757B6D587UL, h6h = 0x6C0D8EAC2D275E5CUL, h6l = 0x0F7A0557C6508451UL, h7h = 0xEA12247067D3E47BUL, h7l = 0x69D71CD313ABE389UL;
    sph_u64 tmp;
    for(int i = 0; i < 5; ++i)
        ulong input[8];
        if(i < 3)
            for(int x = 0; x < 8; ++x) input = (states[(i << 3) + x]);
        else if(i == 3)
            input[0] = (states[24]);
            input[1] = 0x80UL;
            for(int x = 2; x < 8; ++x) input = 0x00UL;
        else
            input[7] = 0x4006000000000000UL;
            for(int x = 0; x < 7; ++x) input = 0x00UL;
        h0h ^= input[0];
        h0l ^= input[1];
        h1h ^= input[2];
        h1l ^= input[3];
        h2h ^= input[4];
        h2l ^= input[5];
        h3h ^= input[6];
        h3l ^= input[7];
        E8;
        h4h ^= input[0];
        h4l ^= input[1];
        h5h ^= input[2];
        h5l ^= input[3];
        h6h ^= input[4];
        h6l ^= input[5];
        h7h ^= input[6];
        h7l ^= input[7];
    //output[0] = h6h;
    //output[1] = h6l;
    //output[2] = h7h;
    //output[3] = h7l;
    if(as_uint2(h7l).s1 <= Target) output[atomic_inc(output + 0xFF)] = BranchBuf[idx] + get_global_offset(0);
#define SWAP4(x)    as_uint(as_uchar4(x).s3210)
__kernel void Blake(__global ulong *states, __global uint *BranchBuf, __global uint *output, uint Target)
    unsigned int m[16];
    unsigned int v[16];
    uint h[8];
    ((uint8 *)h)[0] = vload8(0U, c_IV256);
    for(uint i = 0, bitlen = 0; i < 4; ++i)
        if(i < 3)
            ((uint16 *)m)[0] = vload16(i, (__global uint *)states);
            for(int i = 0; i < 16; ++i) m = SWAP4(m);
            bitlen += 512;
        else
            m[0] = SWAP4(((__global uint *)states)[48]);
            m[1] = SWAP4(((__global uint *)states)[49]);
            m[2] = 0x80000000U;
            for(int i = 3; i < 13; ++i) m = 0x00U;
            m[13] = 1U;
            m[14] = 0U;
            m[15] = 0x640;
            bitlen += 64;
        ((uint16 *)v)[0].lo = ((uint8 *)h)[0];
        ((uint16 *)v)[0].hi = vload8(0U, c_u256);
        //v[12] ^= (i < 3) ? (i + 1) << 9 : 1600U;
        //v[13] ^= (i < 3) ? (i + 1) << 9 : 1600U;
        v[12] ^= bitlen;
        v[13] ^= bitlen;
        for(int r = 0; r < 14; r++)
            GS(0, 4, 0x8, 0xC, 0x0);
            GS(1, 5, 0x9, 0xD, 0x2);
            GS(2, 6, 0xA, 0xE, 0x4);
            GS(3, 7, 0xB, 0xF, 0x6);
            GS(0, 5, 0xA, 0xF, 0x8);
            GS(1, 6, 0xB, 0xC, 0xA);
            GS(2, 7, 0x8, 0xD, 0xC);
            GS(3, 4, 0x9, 0xE, 0xE);
        ((uint8 *)h)[0] ^= ((uint8 *)v)[0] ^ ((uint8 *)v)[1];
    for(int i = 0; i < 8; ++i) h = SWAP4(h);
    //for(int i = 0; i < 4; ++i) output = ((ulong *)h);
    if(h[7] <= Target) output[atomic_inc(output + 0xFF)] = BranchBuf[idx] + get_global_offset(0);
__kernel void Groestl(__global ulong *states, __global uint *BranchBuf, __global uint *output, uint Target)
    ulong State[8];
    for(int i = 0; i < 7; ++i) State = 0UL;
    State[7] = 0x0001000000000000UL;
        ulong H[8], M[8];
        if(i < 3)
            ((ulong8 *)M)[0] = vload8(i, states);
        else
            M[0] = states[24];
            M[1] = 0x80UL;
            for(int x = 2; x < 7; ++x) M = 0UL;
            M[7] = 0x0400000000000000UL;
        for(int x = 0; x < 8; ++x) H = M ^ State;
        PERM_SMALL_P(H);
        PERM_SMALL_Q(M);
        for(int x = 0; x < 8; ++x) State ^= H ^ M;
    ulong tmp[8];
    for(int i = 0; i < 8; ++i) tmp = State;
    PERM_SMALL_P(State);
    for(int i = 0; i < 8; ++i) State ^= tmp;
    //for(int i = 0; i < 4; ++i) output = State[i + 4];
    if(as_uint2(State[7]).s1 <= Target) output[atomic_inc(output + 0xFF)] = BranchBuf[idx] + get_global_offset(0);
on an Nvidia device running CUDA 7.5, on debian:
$ lsb_release  -da
No LSB modules are available.
Distributor ID:    Debian
Description:    Debian GNU/Linux 8.4 (jessie)
Release:    8.4
Codename:    jessie
opencl was installed together with CUDA (following the guide on the download page (I cannot post links yet)).
The code that calls the read and build function is:
HashData->Program = clCreateProgramWithSource(OCL->Context, 1, (const char **)&KernelSource, NULL, &retval);
    if(retval != CL_SUCCESS)
        Log(LOG_CRITICAL, "Error %d when calling clCreateProgramWithSource on the contents of %s.", retval, "cryptonight.cl");
        return(ERR_OCL_API);
    Options = (char *)malloc(sizeof(char) * 32);
    snprintf(Options, 31, "-I. -DWORKSIZE=%d", LocalThreads);
    retval = clBuildProgram(HashData->Program, 1, &OCL->Devices[DeviceIdx].DeviceID, Options, NULL, NULL);
        Log(LOG_CRITICAL, "Error %d when calling clBuildProgram.", retval);
        retval = clGetProgramBuildInfo(HashData->Program, OCL->Devices[DeviceIdx].DeviceID, CL_PROGRAM_BUILD_LOG, 0, NULL, &len);
            Log(LOG_CRITICAL, "Error %d when calling clGetProgramBuildInfo for length of build log output.", retval);
        BuildLog = (char *)malloc(sizeof(char) * (len + 2));
        retval = clGetProgramBuildInfo(HashData->Program, OCL->Devices[DeviceIdx].DeviceID, CL_PROGRAM_BUILD_LOG, len, BuildLog, NULL);
            Log(LOG_CRITICAL, "Error %d when calling clGetProgramBuildInfo for build log.", retval);
        Log(LOG_CRITICAL, "Build Log:\n%s", BuildLog);
        free(BuildLog);
clCreateProgramWithSource()
completes successfully but clBuildProgram() fails with the following logs:
<kernel>:1:26: warning: unknown OpenCL extension 'cl_amd_media_ops2' - ignoring
In file included from <kernel>:4:
./wolf-aes.cl:79:14: warning: implicit declaration of function 'amd_bfe' is invalid in C99
        Y.s0 = AES0[BYTE(X.s0, 0)] ^ AES1[BYTE(X.s1, 1)] ^ AES2[BYTE(X.s2, 2)] ^ AES3[BYTE(X.s3, 3)];
./wolf-aes.cl:74:21: note: expanded from macro 'BYTE'
In file included from <kernel>:5:
./wolf-skein.cl:33:29: warning: implicit declaration of function 'amd_bitalign' is invalid in C99
        if(y < 32) return(as_ulong(amd_bitalign(x, x.s10, 32 - y)));
./wolf-skein.cl:33:20: error: call to 'as_ulong' is ambiguous
cl_kernel.h:14824:24: note: candidate function
ulong __OVERLOADABLE__ as_ulong (long);
cl_kernel.h:14825:24: note: candidate function
ulong __OVERLOADABLE__ as_ulong (ulong);
cl_kernel.h:14826:24: note: candidate function
ulong __OVERLOADABLE__ as_ulong (double);
cl_kernel.h:15502:24: note: candidate function
ulong __OVERLOADABLE__ as_ulong (char8);
cl_kernel.h:15503:24: note: candidate function
ulong __OVERLOADABLE__ as_ulong (uchar8);
cl_kernel.h:15505:24: note: candidate function
ulong __OVERLOADABLE__ as_ulong (short3);
cl_kernel.h:15507:24: note: candidate function
ulong __OVERLOADABLE__ as_ulong (short4);
cl_kernel.h:15509:24: note: candidate function
ulong __OVERLOADABLE__ as_ulong (ushort3);
cl_kernel.h:15511:24: note: candidate function
ulong __OVERLOADABLE__ as_ulong (ushort4);
cl_kernel.h:15512:24: note: candidate function
ulong __OVERLOADABLE__ as_ulong (int2);
cl_kernel.h:15513:24: note: candidate function
ulong __OVERLOADABLE__ as_ulong (uint2);
cl_kernel.h:15514:24: note: candidate function
ulong __OVERLOADABLE__ as_ulong (float2);
./wolf-skein.cl:34:14: error: call to 'as_ulong' is ambiguous
        else return(as_ulong(amd_bitalign(x.s10, x, 32 - (y - 32))));
<kernel>:316:26: warning: unknown OpenCL extension 'cl_amd_media_ops2' - ignoring
Is it possible to define an emulated context for AMD GPUs on Nvidia systems so that the code can be run?
Highlighted
This forum only covers Intel(R) SDK for OpenCL applications.  I see that this code makes extensive use of the cl_amd_media_ops2 extension functions.  These are a vendor-specific extension to the Khronos OpenCL standard.  You can check which extensions are available in your environment when running with query code like in the Platform/Device Capabilities Viewer sample from our sample page.  https://software.intel.com/en-us/intel-opencl-support/code-samples.
Highlighted
This is the output of CapsBasic:
Number of available platforms: 1
Platform names:
    [0] NVIDIA CUDA
There is no found platform with name containing "Intel" as a substring.
I guess there are no emulators for AMD-specific functions.
