OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1719 Discussions
CL_DEVICE_MAX_WORK_ITEM_SIZES on Intel core i3
Abs_S
Hi All,
When i discovery devices (after intstalling openCL intel SDK). I am getting following output...
Why is the CL_DEVICE_MAX_WORK_ITEMS_SIZES are reported 0 / 0 / 0 - what does it mean? could you pls explain whether following output is correct?
Number of platforms: 1
Number of devices in platform Intel OpenCL: 1--- Info for device Intel Core i3 CPU M 380 @ 2.53GHz : ---
CL_DEVICE_NAME: Intel Core i3CPU M 380 @2.53GHz
CL_DEVICE_VENDOR: Intel Corporation
CL_DRIVER_VERSION: 1.1
CL_DEVICE_TYPE: CL_DEVICE_TYPE_CPU
CL_DEVICE_MAX_COMPUTE_UNITS: 4
CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS: 3
CL_DEVICE_MAX_WORK_ITEM_SIZES: 0 / 0 / 0
CL_DEVICE_MAX_WORK_GROUP_SIZE: 1024
CL_DEVICE_MAX_CLOCK_FREQUENCY: 2530 MHz
CL_DEVICE_ADDRESS_BITS: 64
CL_DEVICE_MAX_MEM_ALLOC_SIZE: 971 MByte
CL_DEVICE_GLOBAL_MEM_SIZE: 3887 MByte
CL_DEVICE_ERROR_CORRECTION_SUPPORT: no
CL_DEVICE_LOCAL_MEM_TYPE: global
CL_DEVICE_LOCAL_MEM_SIZE: 32 KByte
CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE: 128 KByte
CL_DEVICE_QUEUE_PROPERTIES: CL_QUEUE_OUT_OF_ORDER_EXEC_MODE_ENABLE
CL_DEVICE_QUEUE_PROPERTIES: CL_QUEUE_PROFILING_ENABLE
CL_DEVICE_IMAGE_SUPPORT: 1
CL_DEVICE_MAX_READ_IMAGE_ARGS: 128
CL_DEVICE_MAX_WRITE_IMAGE_ARGS: 128
CL_DEVICE_SINGLE_FP_CONFIG: CL_FP_DENORM CL_FP_INF_NAN CL_FP_ROUND_TO_NEAREST
CL_DEVICE_2D_MAX_WIDTH 0
CL_DEVICE_2D_MAX_HEIGHT 0
CL_DEVICE_3D_MAX_WIDTH 0
CL_DEVICE_3D_MAX_HEIGHT 0
CL_DEVICE_3D_MAX_DEPTH 0
CL_DEVICE_PREFERRED_VECTOR_WIDTH_ CHAR 16, SHORT 8, INT 4, LONG 2, FLOAT 4, DOUBLE 2
Thanking you all.
Evgeny_F_Intel
Can you please post the code that queries this values?
What is the return value you have from the function?
Also the values for WIDTH/HEIGHT/DEPTH are wrong.
Evgeny
Abs_S
Thanks Evgeny for your reply. I am using JOCL wrapper. I am running samples fromhttp://www.jocl.org/samples/samples.htmlesp.JOCLDeviceQuery. Your answer seems to suggest that the problem is in JOCL implementation.
