OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1719 Discussions
CL_DEVICE_PREFERRED_VECTOR_WIDTH for Intel devices
Alexander_Karsakov
Hello.
I have tried to make some OpenCL-related performance optimization for Intel devices. I want to use vectorization and vector data type with optimal lenght for specified device. I called clGetDeviceInfo(.., CL_DEVICE_PREFERRED_VECTOR_WIDTH, ..) method, but it returns not really optimal values:
uchar - 1
short - 1
int - 1
float - 1
I checked it on GPU Intel HD4600 and CPU Intel Core i5-4570.
I have tried to find the optimal value of the vector length for my problem and got following values:
uchar - 16
short - 8
int - 1
float - 1
If I use uchar16 instead uchar I get x3 acceleration.
I have two question:
1. Why is clGetDeviceInfo(.., CL_DEVICE_PREFERRED_VECTOR_WIDTH, ..) return these values?
2. Is it possible to change these values in future releases? This will make possible to do cross-platform optimization.
Alexander.
Dmitry_K_Intel
Hi Alexander,
You are right - Intel OpenCL devices prefer scalar values as they assume that internal autovectorization will produce better results in most cases. And you are right once more - there are cases where internal autovectorization fails and manual tuning produce better results.
Please check https://software.intel.com/sites/products/documentation/ioclsdk/2013/Intel_SDK_for_OpenCL_Applications_2013_Optimization_Guide.pdf for more info
Dmitry_K_Intel
Hi Alexander,
Alexander_Karsakov
Hi Dmitry,
Thanks for clarification!
Maxim_S_Intel
The caveat: compiler does best job when vectorizing for 32 bits types (like int and float). In contrast for char/uchar using the short vectors like uchar4 explicitly might be more performant as it  better coalesces the memory accesses (since with uchar4/uchar8/etc you operate on aligned data chunks) and also better amortizes the work-item scheduling costs (since you process multiple pixels simultaneously).
