Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Consistent device ordering from clGetDeviceIDs?
When I run a basic OpenCL hello world on my Intel Core i7-3630QM CPU containing Intel HD Graphics 4000, I query and select the Intel platform, then query the devices and select the first device, and proceed.  I just noticed this for the first time, but on some runs I get the CPU, and on others I get the GPU.  Is that to be expected?  What are the rules regarding this behavior, as I don't see it discussed in the OpenCL specification.  I guess that devices may not be consistently ordered between application executions (as I'm witnessing), but I'm concerned that within an application if the order could change unexpectantly.  Would someone please clarify this for me?
Thanks!
Highlighted
We are aware of the issue and it will be fixed in a future release and will notify here.
Raghu
Highlighted
With the release of the Intel OpenCL SDK R3, can you confirm if this issue has been resolved or not?  My quick test doesn't show the issue anymore, but I'd like a more concrete answer.
Thanks!
Highlighted
I can confirm this is still an issue with CL_DRIVER_VERSION 10.18.10.3345.
Highlighted
Generally, it is better to rely on the Device Type (clCreateContextFromType), not the device order.
